Hello. I recently picked up some surplus servo motors, intended for use a three-axis table, eventually. The factory recommended servo drives (and associated accessories) are thousands above my price range, so I've been looking to put together my own power supply. I was thinking about acquiring a Granite Devices VSD-E or -XE, these run at a max 160vdc, and since the motors I have run at that or higher, I'd like to assemble a power supply capable of supplying that voltage. Since I haven't any formal training in electronics, I'd like to run my ideas past everyone here, and see if I can clear up some of the uncertainties I have with the whole thing. The plan, such as it is at this point, is to use a surplus control transformer (I recently picked up a 1000VA model), rectify this to ~165vdc, and use some smoothing capacitors to keep ripple to <5%. Questions I have so far: 1. I tried using this design calculator, and it suggested that for 160vdc and 5.0a, I should be using smoothing capacitors rated to 290v. I had been eyeballing some 20,000uF, 200VDC, 250VDC surge rated caps. Can anyone explain why the suggested ratings might be so high? I assume there must be a reason, although I don't know what it is. 2. I was also curious whether one can have too many caps? If I had, say, 100,000uF of caps, would there be any issues with inrush capacitor charging currents? Or, does placing them after the isolation transformer negate any such problem. Corollary: If I used a larger control transformer, such as a 3kVA or 10kVA model, might that become a problem that needs addressing? I read a site that discussed using series resistors and triacs and stuff to limit charging currents. 3. In my research so far, I haven't run across voltage regulation circuits suited for voltages over 30vdc or so. Does anyone know an inexpensive design that would allow this system to output a regulated 160vdc with continuous currents in the 10A+ range (I'm thinking ahead a bit). 4. I've read that control transformers are typically designed for surge currents up to 7x the rated load. This suggests that I needn't size my transformers based on maximal possible load, but rather that I keep my average load under the VA rating. Can anyone confirm or deny? 5. My control transformer is your typical rectangular laminated transformer type. I noticed that most DIY dc supplies use torroidal transformers. Is there a particular advantage to this type I should be aware of? If anyone could give me any input concerning these Q's, I'd appreciate it. b2b |
The ones you selected should work based on my experience. Increasing Capacitor size, requires an increase in VA.
It is usually very much easier to make additions/corrections due to the nature of construction. Al.
| Power supply questions | scrambled | General Electronics Discussion | 2 | 11-25-2008 10:15 AM |
| Power Supply Questions | DanC | General Electronics Discussion | 1 | 09-07-2006 05:41 PM |
| Pc power supply questions | roni21702 | General Electronics Discussion | 3 | 04-15-2006 01:58 PM |
| power supply questions | SJ781 | Gecko Drives | 2 | 04-26-2004 08:37 PM |
