Old 04-13-2011, 02:52 PM
Fastest1 is on a distinguished road
Fuji SRX3631-5-1/X Magnetic Contactor Wiring?
I am about to reconnect 1 of my machines and would like to reuse the magnetic contactor correctly. I have a manual lathe and a similar contactor was used, upon releasing the Estop, power was available at the contactor but nothing occurred until you pressed the "power start" in this case. Upon pressing this button momentary power was applied to a contact and a jumper locking the switch on until an E stop was triggered. Is this the way most contactors work? I do remember being very suspicious of the jumper really creating a locked on effect but it did. I do know the safety factor is better. I would like to repurpose this contactor to shut down, mach, and all electrical parts of the machine connected.
Old 04-13-2011, 03:15 PM
Al_The_Man's Avatar
There are many examples out there for stop/start PB control where the contactor or E-stop relay is enabled by a N.C. E-stop or stop button and reset by a N.O. P.B. that has a retaining contact in parallel with it across the N.O. button.
e.g. Motor Starter Control Circuits
You can use the main contacts for a either motor control or to switch off any necessary E-stop power, most contactors have at least the N.O. auxiliary contact and most will allow additional Aux contacts to be added or clipped on as needed.
Old 04-13-2011, 03:31 PM
Al, I was going to call you out by name. I should just write you direct. Thanks for your help as always.
What's that gizmo across the contactor coil? jrlandau Bridgeport and Hardinge Mills 1 01-21-2011 11:53 AM
Need Help with Magnetic reversible Contactor Chris64 General Electronics Discussion 12 12-23-2007 02:54 PM
magnetic sensor keithmech General Electronics Discussion 0 07-28-2007 06:04 PM
Fuji Spindle wanchai101 Fanuc 1 07-12-2006 04:28 AM
Contactor help ???? Fabric8r General Electronics Discussion 1 05-26-2006 05:27 PM
