Hi I've just bought a Smallpiece Cromwell S.S. & S.C. 3.5" x 19" Super-Precision Model S.800 Lathe and I need some help to wire it all back up. The spindle was orignally driven by a "Ward-Leonard" electrical system that comprised a 3-phase motor attached to a DC generator that in turn supplied current for a DC motor controlled by an early form of electronic variable-speed drive but at some point in its life the 3 phase motor has been replaced with a single phase motor. I get the feeling it may never have run like this and may not even be possible to do. The attached drawing shows how it is wired at the moment so if it is possible to do it like this where do the two wires shown in red going into the AC motor go? Cheers Chris |
I did not think there was any of those in existance still. The diagram does not look right, the AC motor should drive a DC generator with a variable field control which in turn feeds a DC motor with fixed field. see diag. Al.
| 050817-0827 EST USA creep_pea: Superficially this circuit makes no sense. If you interchange the field and aramature on both the dc generator and the dc motor, then it starts to look better. The ac motor would not normally be drawn with the implication of brushes and a commutator. My guess is that the 512 ohm resistor with the arrowed line thru it is a potentiometer rather than a variable resistor. The potentiometer feeding the field of a dc generator makes sense because this provides a means of varing field excition from zero to maximum, for a generator output voltage from 0 to maximum. Also full field excitation is supplied from the bridge rectifier to the motor at all times. (This is on the assumption that the motor and generator are both drawn wrong.) The two terminals on the ac motor --- no idea at this time. The labels coil and 20 ohm probably need to be interchanged. It appears this is a relay, but as drawn would probably oscillate. There is nothing drawn to detect loss of field excitation to the motor field winding. A field excitated dc motor will runaway if field excitation is lost. . |
| Sorry electrical numpty here. All the motors/generators are disconnected at the moment I just guessed were they went on my circuit diagram whops! I don't know the difference between a potentiometer and a variable resistor so you are more than likely correct, I'll post some pics later today to be sure. Thanks very much for the help Chris |
| Going by the size of the lathe, I would assume the motors are not that large? You might want to look at picking up a more modern DC motor controller and getting rid of the AC motor DC generator. Ones for wound field motors, can often be had cheap surplus. Al.
| 050817-1015 EST USA creep_pea: Chris: As a solution to your problem Al's idea is a good one. A potentiometer is a voltage divider, a fixed resistor with a variable tap contact. A variable resistor, rheostat, is a potentiometer with one end of the fixed resistance unused. The difference in names relates to functionality and useage. If you connect the outer terminals of a linear potentiometer across a constant voltage source, and apply no load to the sliding contact and measure the voltage of the slider relative to one end of the fixed resistor, then the voltage will be proportional to the position of the slider. Adjustable from 0 to the source voltage. Potentiometers are used as volume controls in radios, but are usually made with a log instead of a linear curve. Put a rheostat between a voltage source and a high impedance voltmeter and adjust the slider and there is no voltage change. In this case to get a voltage change there must be a finite load resistance, and output voltage will range from full source voltage to something less but not zero. The output voltage will not be linear with slider position. The output voltage is Vo/Vin = Rl /( Rv + Rl ). Where Vo is output voltage, Vi is the input , Rl is the fixed load, and Rv is the variable resistor. If the load is the variable resistor, then Vo/Vi = Rv / ( Rf + Rv ) . Where Rf is the fixed series resistance and Rv is the variable and load resistance. . |
| I see somone has put some 'modern' silicon rectifiers on it In light of the age & condition, another solution would be to pick up a 240 3ph motor and run a VFD off of single phase. Al.
#10
| As GAR mentioned, there should really be field-loss detection on the motor, if you lost the field control for any reason the motor can wind up fast to dangerous rpm's, some time causing disintegration of the rotor. Al.
#11
| 050817-1044 EST USA Chris: Your bottom right picture is the potentiometer. It is clear this is used to adjust the generator field current from 0 to some maximum value. This provides from zero to a maximum voltage out of the generator to supply the motor armature. At fixed field excitation a dc motor speed is proportional to armature voltage. If you do not follow Al's suggestion, then redraw the schematic as I previously described. Your photos do not provide information on the two wires from the dc area to the ac motor. But Al's idea is going to get you further, faster, and better. Visited your county many years ago. We anchored at Edinburgh and I took a tour of London via train. Meat was in short supply in your country at that time so we had hamburger buns with greens for our meal on the train. As we came into Edinburgh the fog was hanging low, but the castle was visible as if floating in the sky. In London we toured all the special points. . |
#12
| This AC motor is probebly a single face asynchrom motor. Which is reverseble in direction. That means it needs only two connections to line input. And the other connections should be made as on the schematic. Or you must have a direction switch outside. To make this motor run. Otherwise there are no connections to other wires which are comming from outside, such as you draw in your drawing. The connection in your drawing between de AC motor and the DC generator makes no sence. If you run it, Ithink it go's *!@#$%^^&** hell what a fire. Greetings |
