Old 08-16-2005, 10:05 AM
phantomcow2 is on a distinguished road
Choosing a power supply
I am now ready to buy the last link of my cnc mill conversion - power supply.
I believe a 24v is the ideal thing for my setup. I am using a Hobby CNC 4 axis board with 3 stepper motors;
5.4VDC 1.5A
I think thats what is needed here. WHen i select a power supply is there some factor i need to look for or anything?
Would this one work?
http://www.mpja.com/productview.asp?product=12418+PS
Old 08-16-2005, 10:23 AM
buscht's Avatar
buscht is on a distinguished road
I don't use the Hobby CNC board, but I do use that power supply. It works fine and I think that its a good value.
You will need to get a 110v cord. I used one off of an old printer and cut the female end off.
Old 08-16-2005, 10:24 AM
ViperTX is on a distinguished road
Voltage and current rating. Is that the voltage and current rating for each phase of each stepper? If so, then you'll be better off with a supply with a higher current rating....3steppers X 2 phases per stepper X 1.5 amps perphase = 9 amps. With PWM you can probably by with 4.5 amps....but you'll be at the limit....Not sure what the Hobby CNC max voltage is....but a 48 volt supply at 10 amps would be your best bet. Plus since you have a 4-axis card...you could support an additional stepper.
Old 08-16-2005, 11:43 AM
*Registered*
HobbyCNC is on a distinguished road
MPJA has a 28VDC 14A supply for under $40 bucks. Plenty of performance with this one!
Dave Rigotti
HobbyCNC.com
Old 08-16-2005, 01:40 PM
Hey Dave, is this the one your talking about?
http://www.mpja.com/productview.asp?product=15367+PS
Old 08-16-2005, 01:43 PM
Oh and with that one i posted a link for, I would imagine this one could also support another stepper right?
