| I'm building a new CNC router and am baaaaaaaaad in electronics so I drew a circuit in AutoCAD based on some other builders circuits, I dont know if it's a right or wrong configuration, so every body is free to correct me also how can I turn on/off my "DeWalt" router machine,where and how is it connected to this circuit also switches...??? Futur Add-Ons If am going to add a touch probe, where and how is it connected to this circuit also If I want to control the router with some kind of a joystick, where and how is it connected to this circuit |
| What make of BOB it normally would have outputs you could assign to operate a relay etc? Al.
| Sorry I dont even know what a relay is...!! I am only aware of the basics like: The breakout board is responsible of connecting the PC with the machine, like a motherboard in PC the microstepping drivers is responsible of dividing the steps power supplys,....etc ![]() am bad in electronics please help me.. |
These are the specs of the breakout board that am willing to buy 6Axis Breakout Board adapter DB25 for CNC Stepper Motor Driver products, buy 6Axis Breakout Board adapter DB25 for CNC Stepper Motor Driver products from alibaba.com •Built in DB25 male connector. •DB25 Output Pin:P1,P2,P3,P4,P5,P6,P7,P8,P9,P14,P16,P17. •DB25 Input Pin: P10,P11,P12,P13,P15. •DB25 GND Pin: P18-P25. •Power supply: +5V DC. •Built in C-class Optical-coupler. •High quality with Surface-mount Tech. |
| Well it shows 12 outputs but you need a detailed specification sheet with the input and output configurations, in order to interface correctly? Or at least a detailed external wiring requirement. Al.
| You should also include necessary grounding and bonding conductors. Al.
#10
| Is the neutral at ground potential? Otherwise it is not termed a 'Neutral'. Is this a very old installation? ![]() Al.
#11
| I dont understand what do you mean by old installation In Egypt, AC current is 2 terminals, one is dead and the other is Live 220V we dont have grounds except in large machinery and factories If you touched the fridge bare feeted, You'll get zzzZZZZ..!! |
#12
Apart from the Electro-therapy ![]() You may have problems when it comes to being able to 'Ground' your system. I would suggest as a safety precaution you set up your own ground system, by tying the neutral (the 'dead' one) at the panel to a ground rod sunk in the ground. If there is any local power regulation or conformity, code etc, I would consult with them if possible!. Al.
| Tags |
| circuit, joystick, probe, router, spindle |
| Need Help!- Control Circuit for VFD | Khalid | General Electronics Discussion | 8 | 08-21-2010 04:18 AM |
| New Machine Build- electric circuit for cnc 3 ax control | shlxtn | Stepper Motors and Drives | 8 | 11-16-2009 03:12 PM |
| 3 Axis Stepper and Spindle Control Circuit Diagrams | Mad Professor | Controller & Computer Solutions | 1 | 02-06-2009 12:39 PM |
| Need Help!- 240 VAC Control circuit | GaryJ | General Electronics Discussion | 2 | 11-13-2008 03:33 PM |
| Spindle Control Circuit? | boguski.1 | DIY-CNC Router Table Machines | 10 | 03-17-2007 10:24 PM |
