Old 03-24-2011, 07:27 PM
zephyranthes1 is on a distinguished road
48V Relay troubleshoot
For my first build I'm using an SPST 48V 30A relay (see photo 1) with a Gecko G540, and 48V 7.3A power supply. Without the stepper motors connected, I'm trying to get the relay to turn on the router but all it does is click upon reaching the "switch on" g-code in Mach3 and clicks again when I press stop. Not using a VFD or anything, just need to turn the router on & off. I tried using a ohmeter/voltmeter on the relay's output to the router and it's showing nothing when "clicked on." Photo 2 is how I have it connected. I'm using 14 gauge for all 4 wires. On Mach3 I've got the Spindle setup for Output #1, Port #1, Pin #17 and "Disable Spindle Relays" unchecked. What else could I try?
ID:	129792   Click image for larger version
Name:	relay wired.jpg‎
Old 03-24-2011, 07:36 PM
bobsch's Avatar
bobsch is on a distinguished road
Are you checking for voltage or resistance across the output? The output should show zero ohms resistance when the relay is active.
Bob
"Bad decisions make good stories."
Old 03-24-2011, 07:42 PM
Al_The_Man's Avatar
Also check green to blue for 48v when energized.
Old 03-24-2011, 09:52 PM
Thanks for the quick replies.
Checked both voltage and resistance across the output, both still zero when active.
Checked and it's showing 48vdc and about 107vac.
Old 03-24-2011, 10:01 PM
Al_The_Man's Avatar
Is this a 0rdinary 12vac router?
Check the voltage across the two reds (contact) when the relay is De-energized.
Old 03-25-2011, 07:30 AM
doorknob's Avatar
doorknob is on a distinguished road
Can you actuate the relay by connecting one end of the coil to the ground terminal of your 48-volt power supply instead of to pin 5 of the G540?
Old 03-25-2011, 11:52 AM
It's a Bosch Colt 120Vac. Some other 12vac appliances were tried, still nothing across the output contacts.
That's quicker then going through Mach3, but yes it does actuate, nada on the output contacts.
Tried with the another relay (have 2), same issue.
Old 03-25-2011, 12:03 PM
Al_The_Man's Avatar
Very simple, if you have 48v across the coil and can hear it pick up, next with the RED's disconnected check for continuity across the contacts, if not ~0 ohms then your relay is shot, or not picking up.
Confirm by connecting 48v directly across the coil.
If the contact show 0 ohms then with the disconnected red pair, jumper them out, apply 120v power and the router should start.
The above should test every scenario.
Old 03-25-2011, 03:10 PM
You've lost me at jumping. So the red pair from the socket is reconnected to the relay, and 120v goes directly to the socket? Can the 120v come from the power supply's vac terminals? or must it be separate? I'm not very electronically inclined, but I appreciate all the help.
Old 03-25-2011, 03:31 PM
Al_The_Man's Avatar
By jumpering or connecting the two red conductors together you are simulating the relay contact, IOW bypassing the relay, if you do this, the router should be on and run.
On Your 120vac source, assuming the normal black & white conductors, the white should go directly to the router and the black would go to one relay contact, and from the other contact to the router.
  #11   Ban this user!
Old 04-02-2011, 03:12 PM
It works! Thanks a bunch Al and everyone.
Need Help!- 24Vdc Solid State Relay not the same as mechanical relay?? cjchands General Electronics Discussion 7 11-10-2010 12:40 AM
Using a solid state relay as a main stop relay garagefela General Electronics Discussion 4 02-26-2010 04:27 PM
No X axis movement- how to troubleshoot? WayneC Machines running Mach Software 2 02-16-2009 04:54 PM
Need Help!- Help troubleshoot Lincoln SA 200 aawelderswife Welding, Brazing, Soldering, Sealing 2 07-18-2008 09:08 PM
Troubleshoot DNC phoodieman General Metal Working Machines 6 09-21-2006 01:44 PM
