Old 03-14-2011, 05:12 PM
TarHeelTom is on a distinguished road
RC unit
Trying to salvage a few of the mechanical relays from the Bridgeport under rehap.
No problem, pretty straightforward.
But have noticed that almost every relay has a component between the first of the common points and the first NO points.
It's marked:
RC Unit
630 vdc, 250 vdc (or thereabouts)
.1 mfd 100 ohms
Looks like two separate components with amber colored epoxy or similar cast around them.
Any idea why these were there?
Tom
Old 03-14-2011, 06:03 PM
Al_The_Man's Avatar
Are you sure it is not across the coils, snubbers are used on AC circuits to quench back emf or spikes that may occur when the coil releases, the DC equivalent is the reverse EMF diode across the coil.
Old 03-14-2011, 06:11 PM
mike_Kilroy is on a distinguished road
Al, I've seen some designs where the rc networks were put across the contacts also to try to mitigate the sparking on opening an inductive load.
Old 03-14-2011, 06:22 PM
Yeah, Al, I was expecting them to be across the coil, and was surprised when they were not across the coil.
Most of relays are 11 pin tube socket type. Pins 2 and 10 are always (on these, at least) the coil, and the snubbers are connected from pin 1 to pin 3.
And by the way, mine look exactly like the picture you posted.
Tom
Old 03-14-2011, 06:37 PM
Al_The_Man's Avatar
Iv'e found them fitted to contacts on rare occasions, but usually the relay has been under rated and the 'fix' is to add a snubber instead of using the correct size contacts.
If the contacts are switching a high energy DC inductive load, you can get relays fitted with magnetic arc-blowout feature, this is a magnet adjacent to the contacts.
Old 03-17-2011, 07:21 PM
or an engineer who added snubber across the contacts instead of the proper design of adding a diode across the dc inductive load itself to supply path for the inductive voltage spike....
Configuring steps/unit.....what unit? HereinCS Mach Software (ArtSoft software) 2 03-07-2011 07:57 PM
UPS unit Power Supply Product Announcements & Manufacturer News 0 10-11-2010 04:22 AM
Need Help!- FANUC 15-MA Battery unit & I/O unit etc gbowne1 Fanuc 0 05-04-2010 08:47 PM
Unit Problems skipper SolidCam 3 11-14-2009 04:08 PM
I/O unit guhl Fanuc 2 08-20-2007 01:32 AM
