Old 03-14-2011, 12:38 AM
kd7rzv is on a distinguished road
Capacitor Identification
Hey all. First time posting here. I am in the process of restoring some electronics in a guitar amp, but I am having trouble identifying a capacitor. The resistor next to it blew, and there is some scorching on the capacitor, so I am worried that the heat has damaged the capacitor. Here's an image to help with the identification (pardon the size). Hopefully you guys can help me solve my problem.
Old 03-14-2011, 04:28 AM
jeffrey001 is on a distinguished road
153 means 0.015uF or 15000pF
Look like tantalum capacitor
Jeff
Old 03-14-2011, 09:19 AM
Al_The_Man's Avatar
I Agree on the value, but I think a ceramic would do the trick from DigiKey.
Tantalum would normally have the polarity indicated.
You also need to know the working voltage.
Kd7rzy you need to shrink your pic's. before posting, use Irfanview or?
Old 03-14-2011, 09:40 AM
Alright, cool. Thanks much guys. Sorry about the picture size, I'll make sure to use the thumbnail code next time.
Old 03-14-2011, 10:03 AM
I did some looking around at Digikey, and came across these: Digi-Key - 399-4459-1-ND (Manufacturer - C410C153M1U5TA7200)
Would those work?
Thanks,
Scott
Old 03-14-2011, 10:08 AM
Al_The_Man's Avatar
Looks the same as the one in circuit!
As long as the same value. if possible check the voltage across it when working or go by the circuit supply voltage.
Old 03-15-2011, 04:53 AM
Talking
And the good thing is that if you buy 1000 they are only 10 cents each
Old 03-15-2011, 07:04 PM
Yup!
Help with Identification - Compumotor mattgatten Servo Motors and Drives 4 06-10-2010 11:49 AM
Newbie- CNC identification 777string Benchtop Machines 9 01-30-2010 07:54 AM
Ballscrew identification TowerCNC Linear and Rotary Motion 0 08-20-2009 04:37 PM
Stepper Identification tvdbon Stepper Motors and Drives 3 08-28-2007 01:06 PM
V2XT IC identification help Riverside192 Bridgeport and Hardinge Mills 2 07-26-2005 05:36 PM
