Results 1 to 7 of 7
Thread: Schonbuch Electronic
    Gold Member
    Sep 2003
    Does anyone know of a US distributor for Schonbuch Electronic? I am looking for a proximity switch, part# ICBA0805.
    Thanks Darek
    Dec 2003
    Is there anything special about it? If you know the specs. a sub. can usually be found. Unless it is some oddball physical dimensions the electrical characteristics usually don't present a problem.
    Gold Member
    Sep 2003
    Dimensions are 8mm diameter by 45mm length. Electrically it is 10-35V DC 200mA PNP. The only thing special would be the application. It is used on a Walter rotary table for homing. It detects a very small cutout in the ring gear hub.
    Darek
    Dec 2003
    That looks like a shielded type, Is it threaded? Omron make a E2E type 8mm x 30mm short barrel PNP, three wire -X1R5F1 (NO) or -X1R5F2 (NC). 1.5mm sense distance 200Ma.
    Gold Member
    Sep 2003
    No threads. After looking the specs over I believe the E2E-CR8B1 will see the small cutout. It is 4mm in diameter so I will have to sleeve it. It has a 100mA output which is fine in this application. They are just under $100 US from Newark. I found the Schonbuch website, no US distributor.
    Thanks Al
    Gold Member
    Sep 2003
    Thanks for the lead Al, it worked like a charm!
    Darek
    Dec 2003
    No problem. Apart from Omron, Other makes I go to and usually have success with are TURK and BALLUFF.
  • Posting Permissions
