So forgive my ignorance on things electronic, I am much better at the mechanical things than the electronic things. I want to control a single axis of motion. I want to be able to jog, and control direction and speed. The movement doesn't need to be precise, but speed should be pretty repeatable. I would also want to be able to do cyclic motion as well. What would I need to have or do to build and control something like this? |
| Many ways of doing it, from PicMicro, designed from the ground up, PLC, or single axis motion card, either stand alone or PC based. You could do it with Mach and a PC but its a bit of overkill. Al.
| I'm looking for simple and inexpensive. Obviously this isn't a CNC application, so I simply need to be able to set the parameters quickly to get repeatable results. I don't really have any programming skills, so I am looking for something plug and play, more or less. |
| I don't know whether you will find anything of the shelf that is designed to cover all bases. There is usually some customization in every project. Probably the quickest is PLC with a two line display and keypad such a s Maple Systems etc. Automation Direct have cost effect solutions, usually. Al.
| From your description I believe a simple servo drive will do the job. It can control speed, jog, & direction. I doubt from your description you need anything more. Email us at sales@KilroyWasHere.com and we would be happy to quote you a drive to do this. A motor too if needed. Include your phone no if you want an app engineer to call you and discuss your app in detail. |
| All really depends on how accurate your stop positions need to be. I did one that was simply a bodine brushless motor, with built in drive, a siemens logo smart relay and a couple switches. Total cost not including the slide was less than 500 bucks. |
| If this is an industrial application, then have a look at Automation Direct's Sure Servo range. You won't need a PLC unless you need more advanced operator interaction, e.g. changing speeds via touchscreen. Just look for a servo drive that can handle a few speed presets (for jogging) and a potentiometer input to adjust speed. The internal indexer should be able to manage simple cycles, anything more complicated and you might need a PLC. Cheers, Mike |
| Al.
#11
| Hmmmm, maybe I am thinking about this wrong. I will be needing to input data into a PC from a load cell as well as a position sensor. I am building a tensile tester if that helps. I want to be able to do tensile and compressive testing and also want to be able to do cyclic testing as well if that helps. I will need an I/O card for the load cell and displacement sensor anyway, so it may be better to think along those lines for motor control. what I want to avoid is writing code, because frankly I hate it and i pretty much suck at it and don't want to spend time debugging it. So given that, If I am interfacing with a PC using some sort of I/O card and am able to send a signal to a motor controller, what type of signal would a stepper/servo controller need. Does anyone know of a reasonably priced software package that will get me there. obliviously NI's labview will get me there, but that is no in the price range I want to spend. |
| BST LINEAR MOTION-Professional Manufacturer for Linear Motion Products In China | bstlinearmotion | Product Announcements & Manufacturer News | 0 | 11-06-2010 01:15 AM |
| Single axis motion without PC? | marzetti | General Electronics Discussion | 7 | 01-02-2010 10:25 AM |
| single axis control? | jayty97 | Stepper Motors and Drives | 1 | 04-08-2009 07:05 AM |
| Premature Ebay-ulation?!? (single Z axis linear rail) | braidmd | Linear and Rotary Motion | 4 | 11-06-2007 10:08 AM |
| linear slides X-axis single side or dual? | PlasmaGuy | Linear and Rotary Motion | 2 | 02-15-2006 11:44 PM |
