Hello all, my power supply has a three prong plug. I thought that meant the metal case had to be grounded as well. However, I tested continuity between the ground terminal and the case and I got nothing. Could it be that the case isn't grounded? I did this test with the power supply unplugged. Thanks guys, Beau |
| What make/kind of power supply? Is this your PC power supply? Or just a stand alone supply? Normally any metallic chassis should be grounded, including your PC P.S. Al.
| Thanks for you reply Al. It is a stand alone power supply. Model number S-348w-24. It looks very similar(but I don't think its the same) as this one. 350W 24V power supply AC/DC Switching PSU products, buy 350W 24V power supply AC/DC Switching PSU products from alibaba.com Thanks, Beau |
| Much of the equipment coming out of China does not conform to N.A. and European standards, although this states CE approved. Normally this unit would be earth grounded here. If it is mounted to a grounded chassis it would be one way of grounding it. Al.
| If by wire from the input ground being the one from your 120vac socket, That should work. Al.
| In the UK, everything has a three-prong plug, even if it doesn't need a ground connection. In some cases the ground prong of the plug is plastic! This is because most sockets have shutters that won't accept a two prong plug. There's a symbol on devices that don't need a ground, that's one square inside another - stands for double-insulated - mind you, when you take the stuff apart it doesn't necessarily look too safe. |
| Sharing ground on two power supplies? | Patz | General Electronics Discussion | 1 | 01-15-2010 08:38 AM |
| Question about power supplies and ground | kae | General Electronics Discussion | 4 | 12-27-2009 08:21 PM |
| Power supply ground clarification. | Ken_Shea | General Electronics Discussion | 22 | 10-16-2007 09:54 AM |
| Motor supply ground vs Logic ground? | Gashmore | General Electronics Discussion | 11 | 06-07-2005 05:21 PM |
| Power Supply ground question | chas | Gecko Drives | 5 | 04-16-2005 06:48 AM |
