Old 07-26-2005, 02:52 PM
adryan is on a distinguished road
Problem with breakout board
Hi
finally I've come to the easy part..the electronics... ....
I have a breakout board from cnc4pc and have a problem with setting it up with the safety charge pump.
I use pin 16 from the breakout board for the safety charge pump..when powering up, everything works fine, she signal comes through.
When pressing reset in MACH the signal is gone..so o.k.!!
however......
pin 2 till 7 are still high from the pc and the signal goes through the breakout board...the signal even iluminates the LED wich is on the breakout board...so when resetting MACH, and not the safety charge pump I can control the servo's!
Am I doing something wrong?..I thought this would be the easy part....
Adryan
Old 07-26-2005, 03:01 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Did you make sure to ground the boards together?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 07-26-2005, 03:10 PM
yes Paul,
I've connected the following grounds together:
-main power supply
-mini 5V/12V power supply
-relay board
-breakout board
-safety charge pump
Adryan
Old 07-30-2005, 07:53 AM
snaggletto is on a distinguished road
I'm not familiar with those CNC4PC boards, but, the charge pump should only work when Mach is reset. In other words, if power is on to the board, but Mach is not loaded or in E-stop mode, then nothing should work. Only when Mach is out of e-stop (in control) should anything work.
How did you configure the charge pump in Mach? It sounds like you have it set to an 'Enable line' rather than the 'charge pump' output.
Originally Posted by adryan
Hi
however......
Adryan
Old 07-30-2005, 03:33 PM
thanxs for the reply,
I contacted Arturo of cnc4pc and he's trying to sort everything out for me, so I better first wait what he comes up with.
rgds,
Adryan
