Old 01-26-2011, 05:19 AM
pietbez1 is on a distinguished road
adding a motor to motion controll rig
hi,
i have a motion control camera rig. it is a 6 axis rig, track, crab, swing, lift, tilt and pan. i have 2 spare controller boards and i would like to ad a focus puller so i can control the focus on the camera. to do this i would have to get the right stepper motor to work with the controller board.
here is an example of one of the motors currently in the system.
2 phases Hybrid stepping motor Type:
HY200-2240-460-B8
Step angle: 1,8°
Step angle accuracy: 5%
Rated phase current: 4,6 A
Phase resistance: 0,48 Ω
Phase inductance: 1,2 mH
Holding torque bipolar: 130 Ncm
Detent torque: 10 Ncm
Rotor inertia: 330 gcm2
Weight: 0,5 Kg
Insulation class: B
Leads number: 8
the controller board amp output can be adjusted from 0-8 amps. can i use any 8 wire stepper motor or do i need to look at other specs to?
would a 4 wire motor work or does it have to be 8 wire?
the motor does not need as much torque as the other motors as focus pulling is not as heavy as say the track or lift. i would say a 1-2 amp motor would be fine.
could anyone advise me on a motor that would work on my system or what specs to look at.
thanks
PietBez
Need Help!- linear motion stepper motor (open-loop) sahilkit Stepper Motors and Drives 1 11-26-2009 01:30 AM
Other stepper motor motion programs, not NC specifically? Konstantin General CNC (Mill and Lathe) Control Software (NC) 4 01-18-2007 05:14 PM
adding 3rd motor arelewis CNC Plasma and Waterjet Machines 4 12-21-2006 09:26 PM
no motor motion erase42 Gecko Drives 2 05-20-2006 03:24 PM
need help please. dc motor motion controller circuit jbbaby General Electronics Discussion 0 12-06-2005 01:29 PM
