Noise comes from lots of things; we know that already, data wires are what picks up this noise and causes havoc to the very sensitive Parallel port. Now if we think about it, no professionally made machine has data wires running all over the place like most hobbyists insist on doing, if we don’t have data wires, then we don’t have problems with noise. Ok, how. Motor wires create noise, but not affected by it, so we can save on the shielded wire here. Limit switches are nothing more than a safety switch, so why not wire it up like one, One or two E-stop switches and all limit switches, all wired in series (24 volt), no problem with noise, again shielded wire isn’t needed. Home switches (wired parallel) of any type can be found in (24 volt) versions, again no problem with noise, no shielded wire. E-stop and limit switches should always have their own hard wired circuit fully independent of the computer, but it is also an advantage if the computer receives the E-stop signal as well. In the control box the E-stop circuit uses a large relay, by having another small 24 volt relay connected in parallel very close to the breakout board, now it’s here we have data wires, very short, no problem with noise, no shielded wire, and we do the same with the home circuit, another small 24 volt relay. PS: Limit switches are something you don’t run into every day; in fact you shouldn’t touch them at all, just like E-stop they should be wired closed (the safest way), a strong switch with a solid ramp that can force open a sticking contact, wired this way a loose contact or a broken wire will create an E-stop. Last edited by cliffy; 01-23-2011 at 05:19 AM. |
| The main problem is that there's not an inexpensive method of using 24V for switches.
| All switches (E-stop), relays and wiring involved in a 12-24 volt circuit are standard off the self (cheep) easy to find components, whereas shielded wires of the type needed for CNC work isn’t cheep at all, if you can find it. |
| What I meant was, how do you interface 24V switches to the 5V parallel port?
| My E-stop circuit uses a contactor (Relay) to switch off power to the whole system, by having a small relay connected in parallel to the main relay I can send an E-stop signal on to Mach3. ![]() The 5 volt from the Bob is connected to the small relay, (picture above). The second relay is input from home switches. |
| twisted pair shielded or just shielded with whole uniform twist? | chicof | Gecko Drives | 3 | 10-26-2010 05:49 PM |
| What wires should be shielded? | eat | General Electronics Discussion | 8 | 07-23-2007 11:16 AM |
| Shielded versus not shielded cable.....? | REVCAM_Bob | General Electronics Discussion | 1 | 05-23-2007 07:55 AM |
| Shielded cable help please. | Oldmanandhistoy | General Electronics Discussion | 13 | 04-02-2007 07:05 AM |
| DIY shielded wires | HogDog | General Electronics Discussion | 5 | 04-13-2006 07:02 PM |
