Old 01-18-2011, 11:28 AM
neurofen's Avatar
neurofen is on a distinguished road
earthing problem - help
im not much of an electrician but i think i have a problem houston .
the psu ive just built (which i avent turned on yet thankfully) is creating continuity between the earth plate and almost every connector that there is.
bit stumped..
the earth comes from the ac power input straight to a metal plate that the various components sit on, there is not direct link to earth from any of the 3 gecko drivers/breakout board, toroid, capacitors or rectifier? yet they all create a circuit if tested with the voltmeter.. i have lifted up the various components away from the plate and put them on little non conducting blocks. but theres still loops
help.
ID:	124224   Click image for larger version
ID:	124225   Click image for larger version
ID:	124226   Click image for larger version
ID:	124228   Click image for larger version
ID:	124234   Click image for larger version
ID:	124235   Click image for larger version
Old 01-18-2011, 11:58 AM
Al_The_Man's Avatar
If you are testing with a modern electronic meter it is not unusual to measure stray voltage currents due to the high impedance of the meter, at least that is what I suspect is happening, it is better to check with a resistance check, an insulation tester is even better but not always available.
If you use a voltmeter, use a resistor between 500 & 100 ohms, depending on how high the apparent voltage is, across the meter and see if the voltage collapses? If it remains the same then you have a problem, otherwise it indicates stray inductive or capacitive leakage.
This is just ONE of the reasons I prefer to build a system with all commons bonded to earth ground rather than the 'isolate everything' method.
Old 01-18-2011, 12:07 PM
neurofen's Avatar
thanks again al, i have an electronic meter and was using the setting on it which looks like a diode.. continuity i thught.
im going to have to hunt around and see if i can find a resistor, but if i test for voltage, on the dc side of the transformer... i get a reading of 0.16v between the earth and all positive terminals (nothing anywhere else )... i think i might have to learn to use my voltmeter. does this indicate a normal reading?
Old 01-18-2011, 12:16 PM
Al_The_Man's Avatar
I reread you post and when you said you used a voltmeter, I took it to be in the voltage mode, not the diode test range, you really need to try it in the low ohms range on the other side of the meter.
So in that case you do not need the resistor unless you power on and use the voltage range.
If you show a definite low resistance on the ohms scale, then you would need to lift connection one at a time and isolate the point it is grounding.
BTW, your meter shows a battery sign, is you meter battery flat, My Fluke indicates crazy reading when the battery is low.
Old 01-18-2011, 12:21 PM
neurofen's Avatar
i'll do a battery change, hadn't noticed that. thanks
Old 01-18-2011, 12:32 PM
neurofen's Avatar
ok so with a battery change and using the resistance setting marked 200ohms, theres is zero reading between earth and any of the connections except the negative terminals on the dc side where i get a reading when it settles of 0.3 (it peaks monentarily at around 100 then drops to 0.3)
Old 01-18-2011, 12:55 PM
Al_The_Man's Avatar
If you mean by Zero reading, zero Ohms then it indicates a ground connection somewhere, I would first disconnect the load from the power supply and test the various sections of the power supply first.
If still a low reading, start separating the various components/connections to isolate the offending connection, once you have the power supply satisfactorily isolated, then check the load the same way, before connecting to the power supply.
Old 01-18-2011, 02:45 PM
neurofen's Avatar
i should maybe explain that it isnt plugged into the mains and never has been
Old 01-18-2011, 02:46 PM
Al_The_Man's Avatar
I realized that, the post #7 still applies.
Old 01-18-2011, 02:55 PM
mmcp42's Avatar
mmcp42 is on a distinguished road
surely when a PSU is switched off (like yours is) it's a direct short to ground all by itself!
try disconnecting the PSU and measuring
then try just turning on the PSU and see if it generates a voltage
I'm not convinced that you actually have a problem
(but I won't replace your kit or house if it all goes 'orribly wrong )
Old 01-18-2011, 03:09 PM
Al_The_Man's Avatar
Please Elaborate!
  #12   Ban this user!
Old 01-18-2011, 03:14 PM
neurofen's Avatar
ok, so ive disconnected the load from the power supply, and then dissonnected the capacitors/ without them attached theres a reading of about 12 on the voltmeter in resitance mode on the primary side of the toroid (between live and neutral) and then about 0.5 on the secondary side.
should there be continuity between the bases of the 2 capacitors? if so they should be electrically isolated form the earth plate that they sit on right?
Is it safe to plug in the toroid to the mains, without the capacitors attached and only the ac side of the rectifier wired to it (the dc side is unconnected)
does the toroid in anway hold charge?
ID:	124253   Click image for larger version
Surface finish problem - Could you please help me overcome this problem? DMBGO EMCO Lathe 5 08-04-2010 05:33 PM
machine problem or software problem? bcnc Syil Products 8 10-26-2009 09:51 AM
printer card earthing bigz1 Computers and Networking 2 08-28-2007 02:49 PM
