| Hi Same79 , the ULN2003 has open collector outputs to drive the FET's you need pull up resistors between the output and +12V supply or an active pull up circuit for high speed operation as you need to be able to charge and discharge the gate capacitance another way depending on the motor voltage is to use 4 ULN2003 IC's check the data sheet , but I think if you parallel all the darlington transistors in one IC it will sink 4 A ( check the maximum collector voltage also ) connect the common cathodes of the protection diode to the collectors to the motor + supply John |
| Need a bigger hypertherm | energyforce | Hypertherm Plasma | 12 | 11-02-2010 10:05 PM |
| Unipolar stepper motor with ULN2003? | musicworld1 | General Electronics Discussion | 7 | 08-24-2010 07:23 AM |
| Two Input ULN2003 Circuit | w102acd | Stepper Motors and Drives | 18 | 02-19-2008 12:47 PM |
| The bigger hammer | Stepper Monkey | Benchtop Machines | 7 | 07-01-2007 12:43 AM |
| Uln2003 | ipodman1991 | General Electronics Discussion | 2 | 12-03-2006 11:54 AM |
