Results 1 to 2 of 2
Thread: How to connect laptop as DRO
    Nov 2004
    I have several linear scales left over from defunct DROs as well as several old laptops. How can I hook up each to the other so I would have a working DRO for my knee mill?
    TIA
    JohnF
    Phoenix
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    JohnF,
    The basic YADRO system consists of a small hardware translator board, mounted on the machine, and a small software program - which can run on an older reclaimed PC. The YADRO translator takes the signal outputs from up to 4 linear digital scales and combines them into a single data stream which is fed to the PC's serial port. The YADRO software then separates the combined data, performs any needed calculations, displays the results onscreen, and accepts user commands - such as zeroing specific axes, changing units of measure, and much more.
    HOBBYMETRIX - YADRO
    Hope this helps,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. Build Thread- Can i connect.....
    By Gaz. in forum General Electronics Discussion
    Last Post: 05-02-2010, 04:29 PM
  2. RS 232 connect
    By crabbass in forum Haas Mills
    Last Post: 03-11-2009, 02:52 PM
  3. connect to a pc
    By Reid1 in forum Haas Mills
    Last Post: 02-20-2009, 08:37 PM
  4. Need Help!- Connect Heidenhain 145 to laptop
    By paul64 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 02-09-2009, 03:16 PM
  5. Need Help!- Connect a DDK 57f-50 to PC?
    By bigz1 in forum Computers and Networking
    Last Post: 03-11-2008, 08:04 PM
