Old 01-12-2011, 08:09 AM
kolias is on a distinguished road
Power Supply Unit
I want to build a power supply unit and have a hard time to find a toroidal transformer about 25VAC, 200VA
Anyone knows an online store?
Nicolas
Old 01-12-2011, 09:57 AM
Al_The_Man's Avatar
Have you emailed Antek Antek - Your reliable source of transformers, power supplies, and more. he manufactures them and also sells on ebay under Jonango.
Alternatively buy one that is close and take turns off to suit, usually easy with a toroidal.
Old 01-12-2011, 10:13 AM
john_100's Avatar
john_100 is on a distinguished road
Hi Kolias ,
I've just had a look at RS components in the UK RS Components | Electronic and Electrical Components
they list a 200VA 24V transformer number 361-6282
following the link from RS components international www.rs-components.com
to here -
Allied Electronics
this is the nearest I've found
Transformers - Power Products from Allied Electronics
John
ps having had a look at Al's reply go with Antek
Old 01-12-2011, 10:39 AM
ger21's Avatar
Use one of these.
24V CENTER TAP (12-0-12) 10A TRANSFORMER-MPJA, Inc.
Old 01-12-2011, 03:07 PM
[QUOTE=ger21;877698]Use one of these.
24V CENTER TAP (12-0-12) 10A TRANSFORMER-MPJA, Inc.[/QUOTE
Thank you all
Gerry, the one at mpja.com is listed at 10A. What is 10A in VA? I need about 200VA or more
Nicolas
Old 01-12-2011, 03:13 PM
Al_The_Man's Avatar
Roughly equivalent to 240w, (10A at 24v = 10x24 = 240VA).
Old 01-12-2011, 07:21 PM
Thanks again Al
I’m getting lots of help to build a power supply and along with the help I was given this document to go by:
http://campbelldesigns.net/files/pow...ply-part-1.pdf
This document shows the transformer to have 8 wires and the one suggested by Gerry looks like it has only 3 wires (2 blues and 1 white)
The price and specs looks good but I’m only skeptical about the 3 wires.
Also under outputs it says 24VAC @10A (12V-0V-12V). What the 12V-0V-12V means
Nicolas
Old 01-12-2011, 07:31 PM
Al_The_Man's Avatar
This means it has 2x 12v secondary windings, so in your case, if you ignore the 0v centre tap and connect your bridge rectifier to both the two 12v outer ends you end up with a 24v secondary.
This will give you a DC voltage of 24 x 1.414 = ~34VDC.
Off load, some transformers are slightly higher than rated, but then you also have around 1.5v drop across the bridge rectifier.
Need Help!- Need help with the power unit zenon564 General Electronics Discussion 11 05-27-2010 09:54 AM
MAIN BOARD POWER UNIT gabedrummin Fanuc 0 09-27-2009 03:37 AM
Need Help!- Omron PLC I/O power unit agustinus.jusup General Electronics Discussion 2 09-14-2008 12:40 AM
Power Supply Unit math (wood PSU box?) georgeburns DIY-CNC Router Table Machines 1 04-15-2008 07:35 AM
Power supply/preparation unit atifeh General Electronics Discussion 12 07-17-2006 11:32 AM
