Hi all, I'm using a controller with differential DAC output of +-10VDC, 3mA. I would like to amplify the output to say 100mA. Eg; 6.5VDC 3mA to 6.5VDC 100mA Is there any way can I DIY a circuit to achieve this or simply purchase an amplifier/ PLC (that takes in low current DAC and output higher DAC) Thanks. Rgds. |
| What frequency does your 0-10v signal operate at? How much noise can be tolerated in the output signal? What level of accuracy do you need in the output voltage compared with the input voltage? There are a variety of electronic circuits that you could DIY to handle that requirement. In theory, you would want to find an amplifier circuit or IC that has a high-impedance input and a low-impedance output, while meeting constraints such as the ones that I listed above. |
| There is no mention of the power requirement for this DAC input from the manual, support from the local sales person is bad as well. (100mA is just my own guess) So I think I might get help from the forumers here. |
That's a straight forward and simple suggestion. I'm looking at this, http://www.farnell.com/datasheets/57949.pdf Probably will get 1-2pc to try out. Thanks. |
| As suggested, your input may not require 100ma as this IS fairly high for analogue control input? Otherwise you may need an op amp with a higher drive capability than shown. Al.
| Problem- Low Current interface, High Current Motor? | Clackvalve | General Electronics Discussion | 15 | 05-13-2010 12:42 PM |
| Need Help!- servo drive position control by analog 0-10Vdc or 4-20Ma | rai | Servo Motors and Drives | 3 | 01-09-2010 10:11 AM |
| PWM and DIR -> +/-10VDC analog signal | visky | General Electronics Discussion | 1 | 11-21-2007 02:28 PM |
| DigiSpeed-GX 0-10Vdc isolated voltage interface | phomann | Product Announcements & Manufacturer News | 0 | 10-26-2006 11:40 PM |
| current over | bbrreid | General Electronics Discussion | 4 | 08-01-2005 04:43 PM |
