Old 01-11-2011, 11:08 PM
kolias is on a distinguished road
Pilot Lights
I have two pilot lights rated 110VAC and I want to install them on the control station for my CNC. Would they work if I supply them with 30-40VDC?
Also I have a toggle switch rated 10A, 250VAC which I want to control 8 LED lights. Would this switch work if I connect it to 12VDC?
Old 01-11-2011, 11:22 PM
Al_The_Man's Avatar
The switch will work OK.
The lights may not be bright enough to be practical.
Old 01-12-2011, 06:16 AM
Thank you Al
The only place I know in Montreal to get electronics is Acces Electronique and even that is not one of the best. They have pilot lights in either 12VDC or 110 / 250VAC. Since my power supply is 40VDC I though that I will burn the 12VDC lights.
Would you happen to know a good online electronic place to get ON/OFF push button switch, pilot lights etc.? Some in US they dont deliver in Canada
Nicolas
Old 01-12-2011, 08:04 AM
keebler303 is on a distinguished road
You could add a resistor in series with the light to reduce the current to an acceptable level so the 12V bulb would not burn out. Resistor value should be roughly 2.5 times the resistance of the lamp, watch to make sure the resistor is rated for enough power too!
Matt
Old 01-12-2011, 10:18 AM
Al_The_Man's Avatar
One of the best suppliers I have found is DigiKey, they ship to Canada next day air with no brokerage charges, if order is over $200. shipping is free, otherwise $8.
In Canada, Electrosonic is not bad, Newark are the most expensive I have found.
Old 01-12-2011, 03:10 PM
Sounds good, thanks
Nicolas
Old 01-13-2011, 02:10 PM
vegipete is on a distinguished road
Active Components has a location in Montreal. In a pinch I shop there, especially when I want to actually see an object before purchasing. Digikey and Mouser ship quickly and easily to Canada, free shipping as Al said for orders over $200, still cheap for smaller orders. I substantially reduced my purchases from Electrosonic when they closed their local sales counter and warehouse.
Old 01-13-2011, 03:04 PM
Thanks for the tip, Active is not far from my place and I will pay them a visit soon
Nicolas
Old 05-04-2012, 08:30 AM
[quote=LanHarjochee;1109593]I do not quite understand Oh ~ ~ I have the LED lights are interested in, at home, which also bought a lot of LED lights!
Exactly which "america" are you from?
Problem- Lights out... jpastor1234 Haas Mills 3 08-16-2010 10:22 AM
Red lights on amp, is it dead? smithgrind Fadal 4 03-29-2010 05:38 PM
SL-10 lights-out running? shawncnelson Haas Lathes 15 04-20-2009 09:44 PM
Problem- TNC 145 cs Lights On mjp Bridgeport and Hardinge Mills 6 01-18-2009 08:25 PM
OT dynamic lights gabi68 General Electronics Discussion 1 09-25-2007 11:35 AM
