Old 01-10-2011, 11:48 PM
same79 is on a distinguished road
Determining frequency rate????
I would like to ask about frequency rate of stepper driver and how to find and control it?
Old 01-11-2011, 05:11 AM
neilw20's Avatar
neilw20 is on a distinguished road
In some microstepping drivers the frequency is dependent on the supply, and the stepper inductance.
On others it is a fixed fixed value, or may change dynamically depending on speed and current setting.
Why do you want to control it?
Just drive the step pulses to the speed you want to go, within the specs for the driver/motor/voltage combination.
Above some minimum speed the acceleration/deceleration need to be controlled so steps are not missed because the inertia of the machine becomes an issue.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Need Help!- Control Plunge rate & Retract rate GEORGETOUBALIS G-Code Programing 8 04-13-2009 06:12 AM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 05:37 PM
Feed Rate and Spindle Rate for this cut? DroopyPawn General Metalwork Discussion 20 11-21-2007 11:12 PM
Relations between chopping frequency and step pulse rate bunalmis Stepper Motors and Drives 14 05-30-2006 11:37 AM
Determining VA load Swede General Electronics Discussion 11 04-10-2004 04:00 PM
