Newbie here. I bought a kit on ebay just like this one ...Wholesale cnc kits 3axis Nema 23 Stepper Geared Motor with 15:1 Gear Ratio252oz in/0.6A I'm pretty sure I have it wired correctly. I have used a parport tester to send signals to the controllers and I can get the motors to make humming and squeally noises but the motors won't turn. Can someone help? |
| looking at the info for your kit the motor has two centre tapped windings of 20 ohms with the centre taps not connected (ie using all the windings) with a 24v supply this gives you a maximum motor current of 24/20=1.2A no matter what setting over 1.2A on the driver the lowest current setting available is 1A but this drops to 60% when idle = 0.6 A if the wiring is correct in so far one winding is connected to terminals A+ and A- and the other to B+ and B- try reversing the connections to one winding John |
I did try reversing the wiring for the motors as one of my tests but still no joy. The motors still tease me with hums and squeals. I may be able to use them as a musical instrument but I would really like to use them for CNC. I appreciate you help John and I hope you don't take my attempt at humor the wrong way. I just finished drawing my wiring in Visio and have attached a jpeg of it. |
| apart from the missing direction signal to the Z axis the diagram looks like i'd expect just in case its some thing funny with your test signals too narrow pulses ? try the circuit on the Gecko website http://www.geckodrive.com/upload/STPDIRTester.pdf can't think of any thing more at the moment John |
| How fast are you trying to spin them? Geared 15:1, you won't get much speed at all out of those. You may be trying to spin them too fast, which is causing the noises.
Remove power from the circuit. Disconnect the Y and Z stepper drivers, set up X only. 1st. The drives work on pulse (step) & and direction. You cannot have the direction and enable pins connected. Every time there is a change in direction (dir) your driver will be disabled. The direction pin and step pin should be connected to pins (2 & 3) for X, (4 & 5) for Y, (6 & 7) for Z. Find out which pairs of pins refer to X, Y, Z. The enable pins should be connected together, you can use either a high or low (ena+, ena-) to enable them. 2nd. Each stepper driver should be connected individually and directly to the power supply, do not daisy chain. You want each driver to see the same current. 3rd. Double check the voltage and current needed for the enable function. 4th. In summary, wire each driver directly to the power supply. The enable pins can be wired together (ena+, ena-). It looks like you have chosen (ena+) which means that (ena-) will have nothing connected to it. You only need (Puls , Dir ) connected to the BoB. In other words, if your BoB uses pins 2 and 3 for X step and direction, then pin 2 of the BoB would connect to either (Puls + or Puls-) NOT BOTH. Pin 3 direction would connect to either ( Dir+ or Dir-) NOT BOTH. There should be 3 pairs (Puls, Dir) wires total. Do not give up you are almost there. Hope this helps, Iron-Man |
| the plus and minus terminal for each input on the stepper driver are the input L.E.D's in the opto isolators the internal current limiting resistor will be around 220 ohm's for a 5v input since TTL gates can sink more current than source connecting the + inputs to the +5v is correct I expect you need to sink about 16mA from the negative input to 0V / ground ( the maximum for a standard TTL gate ) ps to me the enable input is more of a disable input as the motor is enabled when the led in the opto isolator is off that is when the input is not connected or the + terminal is at +5V and the - terminal is at logic 1 = +5v Last edited by john_100; 01-01-2011 at 11:38 AM. Reason: add enable i/p note |
#10
As for the enable pins they are 5v also. Should I connect them to each other (+ to -)? Is that what you mean? |
#11
| No do not connect them (ena- to ena+) together. You only need to use 1 enable pin per stepper driver. You must decide if you want low ( ena-) or high (ena+) signal to enable the drivers. In your schematic you show 5v being used to drive the enable function. Try using (ena+) since you already have it set-up. Iron-Man |
| Newbie- cant make my lathe chuck turn!! | yatz | Shopmaster/Shoptask | 6 | 07-20-2010 01:46 PM |
| Motors will not turn | BrassBuilder | Mach Software (ArtSoft software) | 2 | 02-16-2010 08:47 PM |
| Should my motors make noise? | thegimpster | DIY-CNC Router Table Machines | 2 | 06-04-2008 12:21 PM |
| G320 make my servo turn only one way | gcamlibel | Gecko Drives | 1 | 03-05-2007 01:35 PM |
| I Cant Get my motors to turn | bigbigjimb | General Electronics Discussion | 3 | 10-24-2005 10:14 AM |
