Old 12-31-2010, 02:38 PM
Drools's Avatar
Drools is on a distinguished road
only take a minute.
I have a EasyDriver from Sparkfun, it is a small stepper driver. Good for a nema17 which is what I want to use with it. I'm looking for some code for an Atmega48 series uC to generate the step signal. All I can find is code for the Arduino but I want to use C in AvrStudio. (my Arduino is broken)
I could also use a 555 timer if someone has a circuit diagram for that.
Thanks for the help.
Happy New Year!
Old 12-31-2010, 05:14 PM
Drools's Avatar
I just thinking here but is the step signal similar to PWM? or maybe the same as PWM?
I know the direction signal is just a logic high/low.
Old 12-31-2010, 05:38 PM
irving2008 is on a distinguished road
Step signal is just a pulse, typically about 5 - 10uS or so wide, pulse rate depends on how fast you want the motor to turn. Generally for fast pulse rates you need some sort of ramp up (accelerate) and ramp down (decelerate) approach to avoid missing steps due to mechanical inertia.
If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
Old 12-31-2010, 05:59 PM
Drools's Avatar
So the pulse frequency varies not the width as in PWM. I think I can program a pulse from the AVR using a timer. Thanks!
Old 01-01-2011, 05:18 AM
mmcp42's Avatar
mmcp42 is on a distinguished road
I'm using the same board (3 of them) but driven from an Arduino Uno
If you like I can post the code (what I rote) that interprets gcode directly to give step and direction control for all 3 axes
No acceleration though
Old 01-01-2011, 01:18 PM
Drools's Avatar
Sure please.
My Arduino does not communicate with the PC, the serial interface does not work. (not even with a USB to Serial converter).
Maybe I can brain storm converting the Arduino code to GCC.
Old 01-01-2011, 01:50 PM
mmcp42's Avatar
without a working serial interface you are doomed!
Old 01-01-2011, 01:52 PM
Drools's Avatar
I was thinking of going back to using AVRStudio4 and my AVRISP mkii and program my chip that way.
Old 01-02-2011, 01:13 PM
Drools's Avatar
mmcp42, how hot does your easydriver get?
What voltage are you using?
I have mine working with a nema17 motor with a coil resistance of 5.3ohms@12VDC.
The chip gets fairly hot. I was using a nema17 motor with a coil resistance of 15.1ohms but the motor got fairly hot along with the chip.
Old 01-02-2011, 01:37 PM
mmcp42's Avatar
I'm using a stepper from an Epson scanner
about half the size of a NEMA17 as far as I can judge
One EasyDriver gets almost too hot to touch, but keeps soldiering on!
that's the Z-axis
x and y are cold even when busily stepping away!
it may be that Z need to hold itself stationary more than x an y
ISTR it has over-temp detection so will shut down if fertiliser gets too close to aircon
oh and I have it so that the card is disabled when the axis is stationary, that keeps it a lot cooler
oh and I'm using a 9v wall-wart
motors are stone-cold
6 arc minute backlash =? diyengineer Mechanical Calculations/Engineering Design 4 09-13-2010 06:05 PM
Need Help!- Setting inches per minute revricky Rockcliff Machine 11 08-27-2009 01:20 PM
Newbie- About to build. Needs some last minute thoughts. mikeofaustin DIY-CNC Router Table Machines 5 06-22-2009 11:56 PM
15 minute Aspire? bsimages Vectric 1 01-30-2009 07:51 AM
inches per minute planescott Mach Software (ArtSoft software) 7 02-24-2006 06:29 PM
