Old 12-20-2010, 02:25 PM
mrendu43 is on a distinguished road
single phase motor
anyone knows is it posible to drive singlephase ac iduction motor on frequency higher then 50 hz to get more speed?
Old 12-20-2010, 03:12 PM
Al_The_Man's Avatar
You would probably have more luck that going lower than 50hz, split phase induction motors tend to drop out of run if the rpm/load is taken too low.
Old 12-20-2010, 04:37 PM
vanjast is on a distinguished road
The motor inductance (coil values) and phase shift capacitance starter, are probably tuned for 50Hz, max torque..etc.
So probably not - the higher frequency would result in higher 'resistance to motion'/or un-synced 'phases'
fitting a 110v or 220v single phase spindle motor on a 3 phase machine mwood3 Benchtop Machines 12 10-12-2009 09:53 PM
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
Need single phase motor help bob1112 General Electronics Discussion 8 02-24-2008 07:48 PM
Single phase IR motor with a VFD? in2steam Phase Converters and VFD 2 07-10-2007 11:23 AM
