hi !
the mosfet grid acts as acapacitor.
if you don't discharge the grid capacitance, it stays on for a time until leakage current do the job...
the same for igbt's
at least use a bleeder resistor of 1k...
for efficient command of mosfet or egbt you must use a push pull stage to have a fast charge/discharge otherwise the transistor will stay in linear mode and generate a lot heat... in switching mode heat is minimal (full current and minimal voltage across transistor or no current and full voltage)
hope this will help
regards
sourisbulle
LinkBack URL
About LinkBacks
