Old 12-02-2010, 10:41 AM
patriciooholegu is on a distinguished road
should a driver board need negative voltaje???
Hey people.
There is something rolling around in my head since a few days now, because making a job of reverse engineering on a Ricoh stepper driver pcb, and found that:
1 of the connectors of the board needs 24 volts for motor powering.
1 connector it is 100% sure for ground.
1 of the connectors goes to a PNP transistor and also motor powering and that’s my question:
If found a PNP transistor on the board, obviously together at the side with 24v, should I suspect that I need negative voltage on that?
Should be of the same current rating than 24v?
The device is 2SB1031 and here is the datasheet (The symbol –, negative, is everywhere):
2SB1031 pdf, 2SB1031 description, 2SB1031 datasheets, 2SB1031 view ::: ALLDATASHEET :::
Please be advice that im not talking about ground connections here.
Please Help!!!
Old 12-02-2010, 12:42 PM
george4657 is on a distinguished road
It sounds like this is an H bridge circuit.
Google H-bridge BJT and you will find circuits that use npn transistors to drive motors.
And no you do not need a negative voltage for this.
George
Old 12-02-2010, 07:28 PM
George
This particular board have a PNP transistor. Not NPN.
On the 24 volt connector it is a rectifier diode.
both, the rectifier and the PNP transistor end up at going to motor power mosfets
Old 12-14-2010, 05:38 AM
vanjast is on a distinguished road
That link goes to the 2SD1435 ?
An PNP does require the Base voltage to be -ve relative to the Emitter, to turn on. This does not mean that the base voltage has to be -ve wrt ground/0-volts. The datasheet probably refers to relative voltages, not absolute.
It sounds like the PNP is being used as a gate driver for N-type mosfet.
It's another (cheaper) way to switching the mosfet on faster. It is more advisable to use a mosfet driver chip for this purpose.
The diode could either be a blocking diode (preventing voltage going back into the circuit causing damage) or a freewheeling diode (connected to the drain) to suppress the power spikes from the motor. If connected to the gate, it's probably a clamping zener diode as mosfet gates are usually limited to 20V max.
Google 'driving mosfets'.. there are plently app-notes on this.
how see the current resistance sense voltaje on osciloscope? brutto General Electronics Discussion 5 03-23-2010 06:04 AM
Ayuda con Voltaje de Interfaz y de Drivers MauroKSS Spanish CNCzone 1 11-09-2009 09:50 AM
voltaje y ampreaje Diegone Spanish CNCzone 3 07-27-2009 03:26 PM
single axis driver and a b.o.b.,or multi-axis driver board .xXACEXx. Stepper Motors and Drives 3 07-02-2007 11:13 PM
New and need your help Please (driver board) Oldmanandhistoy General Electronics Discussion 17 06-12-2005 04:48 PM
