Old 11-30-2010, 09:04 PM
cambridgecnc is on a distinguished road
CNC Master and Slave problem
We have a cnc router with an A and X drive slaved together and controlled by a usbcnc controller called usbcnc cpu5
Eding CNC - PC based CNC control. When I enable the drives in the software the drives move slightly and put the machine out of alignment which I can fix by jogging at high speed. The control board maker insists it's machine tension within the cnc but it moves freely with no power. I am using leadshine drivers to control the two steppers which are 6 newtons. Wondering if anyone has any tips to fix this? Maybe change the dip switch settings on the steppers? Anytime we turn it off and on it needs to be realigned and makes an awful noise until we high speed jog it. Thanks
Problem with X and A slave axis deemon328 Rockcliff Machine 6 09-02-2010 01:00 PM
Need Help!- Master and Slave axes in EMC2+Montec Andrey_Ld LinuxCNC (formerly EMC2) 0 07-03-2010 02:56 PM
Master Slave Trolley Arangements? technomage Linear and Rotary Motion 0 05-23-2007 04:36 PM
master-slave servos js412000 Servo Motors and Drives 4 03-09-2007 12:36 AM
Master and Slave servo Builder Servo Motors and Drives 3 11-02-2004 08:55 AM
