Old 07-07-2005, 03:02 PM
Nono's Avatar
Nono is on a distinguished road
Cooling Fan Power
I am planning on buying some fans for my power supply and plan on running them off of the capacitors for the motors..... My cap voltage is 33.6 vdc so do I use a fan with a higher rating like 48vdc or will a lower voltage fan like a 24vdc fan take the power? I think that the 48v fan is what I need but will this fan burn out because inadequate voltage?
If you have and don't use it, you still have it.
Old 07-07-2005, 03:46 PM
Al_The_Man's Avatar
If you intend buying, why not go with one 5" or 6" 120vac around 100-120cfm
http://www.blowerwheel.com/fans-cool...med-square.htm
Surplus are available and you do not have to dick around with two or three 2" fans that may be low cfm and maybe intended for lower wattage supplies.
Most industrial cabinets use 120vac type.
Old 07-07-2005, 04:12 PM
Nono's Avatar
I considered using an ac fan but have access to dc fans at .99 to 2.50 each. Also would like this fan to leach off the capacitor after shutdown.
Old 07-07-2005, 09:28 PM
sendkeys is on a distinguished road
seeing your only using 33 volts you should be able to use a voltage regulator from radioshack with any 12volt computer case fans. should only be couple bucks.
Just a idea
Old 07-07-2005, 10:33 PM
Nono's Avatar
Back to the question,, Can I use a fan with a higher rating like 48vdc or will a lower voltage fan like a 24vdc fan take the power with a 33 volt cap?
Old 07-07-2005, 10:57 PM
Al_The_Man's Avatar
Can you even get a 48vdc fan? A 24v on 33 will turn a bit faster and maybe have a bit shorter life, but I would imagine there is quite a bit of tolerance on the voltage rating. Or use three 12v'ers in series.
Old 07-08-2005, 02:04 AM
Nono's Avatar
Al 48v .23a 120cfm 48db(like a lawn mower).. Do you recomend a 24v instead of a 48v fan. I could try both and find out the life span for all to know.
Any recomendations on a timer/counter for power on time?
Old 07-08-2005, 12:06 PM
Al_The_Man's Avatar
Most of the current DC fans are brushless DC which have electronic switching inards.
So They may not take to high variations of voltage compared to thier older brush type counterparts.
For a Hours Run meter, I would go with AC because of the accuracy, you can pick them up on ebay for around $10.00. If you have a powerup/e-stop relay, you could use a spare n/o contact to switch the 120ac.
Old 07-10-2005, 09:32 AM
Nono's Avatar
Did anybody notice radioshack.com is gone? Al I will keep an eye out for one. will I need to run it through a relay? shouldn't I run it off my main ac on switch? It would be for mtbf's for the controller components not the machine itself. As for the machine I would want it set up off spindle power to start the timer wouldn't I?
Old 07-10-2005, 10:08 AM
Al_The_Man's Avatar
I found out the day they switched over to CircuitCity, but I though they had only closed in Canada.
You could put the hours-run across the power transformers 120v in.
water cooling CNCadmin Laser Engraving & Cutting Machines 30 04-01-2005 05:13 PM
Air Cooling? senor J. General Metal Working Machines 2 03-14-2005 08:05 PM
cooling alarants WoodWorking 8 09-21-2004 07:59 AM
Cooling Head motomitch1 Parts for Radio Control Models 1 02-06-2004 12:30 AM
Cooling question CNCadmin Computers and Networking 9 11-18-2003 07:49 AM
