Old 07-06-2005, 07:50 PM
Gold Member
freak_brain is on a distinguished road
CPU Cooling Fan Wiring
Can anyone tell me how to wire a cpu cooling fan? Three wires.....
yellow
red
black
-Allen
Old 07-06-2005, 08:01 PM
sendkeys is on a distinguished road
red is to the 12v wire black is to the ground.
yellow is the rpm wire only used if you plug it into the board.
most the time
yellow on the power supply is 12volt ,black is ground. red is 5
so red (fan)to yellow-black to black.
I would use the wires used for harddrives/floppys. Stay away from the main board wires. you dont want to add noise.
Old 07-06-2005, 08:08 PM
Gold Member
Wow!! Got to love this site, superfast response to your questions. Thanks sendkeys, I do appreciate it!!
-Allen
Old 07-06-2005, 08:11 PM
np happy to help when i can.
Old 07-07-2005, 06:33 PM
Imagineering's Avatar
Imagineering is on a distinguished road
If you intend using the Fan in your Power Supply, give a thought to connecting it across your smoothing Capacitors, (dropping the Voltage with a Regulator if needed), as this assists in bleeding the Voltage from them on shutdown. A nice safe 'Zero Volts' remain, the next time that you open the PSU Case.
Old 07-07-2005, 10:19 PM
Gold Member
I was planning to but thanks for the information...
-Allen
Water cooling CPU CNCadmin Computers and Networking 23 07-13-2006 05:30 PM
water cooling CNCadmin Laser Engraving & Cutting Machines 30 04-01-2005 05:13 PM
Air Cooling? senor J. General Metal Working Machines 2 03-14-2005 08:05 PM
cooling alarants WoodWorking 8 09-21-2004 07:59 AM
Cooling Head motomitch1 Parts for Radio Control Models 1 02-06-2004 12:30 AM
