Old 11-19-2010, 06:00 PM
dingo0722 is on a distinguished road
Step up/Step Down transformers is there a difference
I am in need of a transformer to take 240 3ph to 460 3 phase. Can the same transformer be used to step up or step down based on the coil winding ratio
www.machmachine.com
Old 11-19-2010, 06:50 PM
Al_The_Man's Avatar
For the most part you should have no problem, some manufacturers have a compensation winding on the secondary, which could affect the efficiency or ratio slightly.
I have often done it with no apparent problems.
Old 11-25-2010, 06:26 AM
bharbour is on a distinguished road
You should be OK, just make sure that the low voltage side can handle the current:
I_low_v = I_hi_v * (V_hi_v / V_low_v)
So your 240V current will be about 2X your 460V current.
BobH
Old 11-25-2010, 08:37 PM
thanks for the info. I ended up buying a transformer from Sunbelt to go from 240 delta to 460. I got a 30 KVA unit which is more than sufficient. It cost for $750.
www.machmachine.com
Old 11-26-2010, 06:54 AM
mike_Kilroy is on a distinguished road
good price.
Need Help!- Loosing step more and more on X axis only after reducing the accl/velocity step motor Calico DIY-CNC Router Table Machines 3 04-09-2010 07:23 PM
Need Help!- Step/Direction pins should be Step FWD and Step BACK rayscott Mach Software (ArtSoft software) 6 02-09-2010 05:57 PM
Full step and half step hybrid driver? rkremser Stepper Motors and Drives 4 11-20-2008 10:22 AM
Step by step cnc plasma with parts list and links. massajamesb CNC Plasma and Waterjet Machines 8 07-08-2007 10:22 PM
difference between x - y step lenghts newbie puzzled rkremser DIY-CNC Router Table Machines 2 04-20-2005 01:10 PM
