Old 11-15-2010, 10:09 AM
TheProCreator is on a distinguished road
Where oh where can I grab Z plate input???
Trying to get pin 15 for Zplate input on this 6560. Tried turing the board over and I can not even get a signal at the pad 15 of the DB25.
One suggestion was that I add a pull up resistor from +5 volts to pin 15 on the DB25. How the heck do I do that?
Has anyone added a Zplate successfully to this board?
Please HELLLLLLLLPPPPPPPPPPP!!!!
Name:	Screen shot 2010-11-14 at 10.43.30 PM.png‎
ID:	119230   Click image for larger version
Name:	Screen shot 2010-11-14 at 10.51.57 PM.png‎
Old 11-15-2010, 11:20 PM
SDesigns is on a distinguished road
Hi TheProCreator,
I don't have any experience with this board i'm affraid.
Have you tried to contact the manufacturer?
Old 11-16-2010, 12:03 AM
Yes I did and the only way was to solder a direct link at the r25 pad.
Thanks for the response, but actually (perhaps on purpose) I fried this board today. I decided to get a g540 as a replacement. I needed something to control my VFD anyway.
Old 11-19-2010, 10:09 AM
neric is on a distinguished road
fry board
just check the diodes ($0.60 ea) and then replace the TB6560 ($4.00 ea) under that heat sink then make sure that your motors dont draw more than 3A otherwise you will need current limiting (u can do that in the setting or u can build one...look on line for schematics) about pin 15 I directly solder 24 AWG stranded wire to it on the bottom of the board and then insolated and secured that with couple dabs of electronics silicone...open the probe in pin setting and designated pin 15 as active in Mach3 assign the VB code to the auto zero button in Mach3 and it is working like a charm...when I have time I will post the pics
Need Help!- Can your Z home/limit input also be used for a touch plate?? TheProCreator DIY-CNC Router Table Machines 7 11-15-2010 01:47 PM
Grab bags of end mills!! gwschultztool EBAY ADS 0 07-21-2009 10:52 AM
Ebay Changes, another money grab !! Al_The_Man CNCzone Club House 3 09-02-2008 03:49 PM
Seventeen cent grab bag MrWild Stepper Motors and Drives 1 03-21-2006 10:34 PM
Hows this for a 30 dollar grab bag? trilect Smithy 3 07-29-2005 02:40 PM
