Old 07-01-2005, 10:49 AM
DJB282000 is on a distinguished road
Question Drive selection help needed
First things first
I am a newbie to the CNC world and would like to thank all of you for sucking me in and then pushing off the cliff. I have been reading for about a week and a half now nonstop.
My question is which drives to buy. I am going to be using stepper motors from Anaheim Automation ( http://www.anaheimautomation.com ) to drive a plasma cnc/router.
The model # 34D311s
Torque 2.5 RPS -- 400oz
I am hoping that this will be adequate
I would like to stay away from the multi axis drives (1 board) so I guess that leaves the geckos. Anaheim also sells drive but I do not know anything about them.
Any help here would be appreciated.
Old 07-01-2005, 11:30 AM
Nono's Avatar
Nono is on a distinguished road
Versitility is Gecko. Small. up to 7amps. No better out there for the money.
Whats was your Question again? Got any pictures?
If you have and don't use it, you still have it.
Old 07-01-2005, 11:57 AM
No pictures yet. I am still trying to figure out what i am going to build and have lots of ?. once i get started i will get some pic and place the build on the sight.
Old 07-01-2005, 12:03 PM
ViperTX is on a distinguished road
What are you the steppers for....what are they going to be driving?
Old 07-01-2005, 12:38 PM
H500 is on a distinguished road
The motor you specified uses about 5 amps per phase, so that rules out the hobby class boards. The gecko's seem like a good choice.
Old 07-01-2005, 11:20 PM
The 2 anaheim motors that I have will be driving the X and Y axis. According to the tag on the motor they run at 2.8 vdc, 5.5A. I would like to get a set of drivess and the software and play around with them a lil bit before i start to draw up my table.
Any thoughts on what i shoud be using for the interface between the computer and the drives.
I am thinking about using Mach2 software.
The more I read the more ?'s I have.
tks for the help.
Old 07-02-2005, 12:01 AM
Well on the computer you'll need a CAM package like Mach2 for Windows (TurboCNC for DOS, etc.), that will interface to a "parallel port breakout board" which will mostly reside in a chassis that contains the Geckos, and a power supply(s) for the Geckos, the breakout board and the steppers.
I'm sure we'll have some discussion on whether Mach2 is a CAM package or not.
Old 07-04-2005, 04:40 PM
I have been looking belive that i am going to go with gecko's and will be ordering them after the 4th. I am also looking at the axxus break out board but i dont see anything on the site about optical isolation. is this needed when used with a plasma cutter.
tks
Old 07-04-2005, 04:57 PM
ger21's Avatar
I'm not sure if Dean is still sellin gthe Axxus boards. I've seen a few posts saying people couldn't get in touch with him. If you're building a plasma cutter, go with the Sound Logic board and the Torch Height Control board. http://www.campbelldesigns.com
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
CAM Software selection help; fyffe555 General CAM Discussion 3 07-25-2004 09:13 PM
Cheap 0 Clifton and servo drive selection (advice needed) Konstantin General Electronics Discussion 4 04-14-2004 10:21 AM
Motor selection advise needed? Servo or Stepper Beezer DIY-CNC Router Table Machines 1 03-21-2004 12:24 PM
Help needed with plans selection DJ Morrow DIY-CNC Router Table Machines 3 12-31-2003 03:16 PM
