Old 11-09-2010, 05:30 AM
cjchands is on a distinguished road
Unhappy 24Vdc Solid State Relay not the same as mechanical relay??
Hello Guys.
I have this 2 brand new Solid State relays
(Salsar, SSR-10DA)
SSR Relay (SSR-10DA) - China Solid state relay,ssr,relays in Relay & Contactor
which I am currently use to close NO contact with 24Vdc input from CNC controller manual buttons (spindle CW and spindle CCW).
The LED is is lid when push on/off...but the contact (Load Voltage: 24-380VAC) doesn't seem to close......
Question is...this type of solid state is no good to close the contact?? Or am I just having bad Solid State?
Alternatively....mechanical relay works just fine....
I thought it works just the same?
Old 11-09-2010, 09:52 AM
Al_The_Man's Avatar
I see no reason why it shouldn't work?
I assume you are switching the AC to spindle direct, what type of spindle?
how are you achieving the reverse (CW/CCW)?
Old 11-09-2010, 07:33 PM
Al,
I was pretty confident that should work too.
I connect the 2 SSR to FWD/REV/COM on the inverter to drive spindle CW/CCW.
Normal relay works. Perhaps just bad solid state relay?
Old 11-09-2010, 07:41 PM
Al_The_Man's Avatar
I am still not clear as to what you are controlling, those particular SSR's are intended to switch an AC load directly.
If you are using them on a VFD type controller using theVFD logic inputs you are using the wrong device, they will not switch the low voltage low impedance input of a VFD.
Old 11-09-2010, 08:59 PM
I think you are right.
I am using those LOGIC for the contact VFD, not the load itself. I thought it could be used similarly to the normal relay.
Old 11-09-2010, 09:04 PM
But I am wondering why can't the logic contact be connected? it is just the contact open/close?
Old 11-09-2010, 10:17 PM
Al_The_Man's Avatar
NO, the SSR has to see a compatible load and voltage type, the CW/CCW inputs are low level logic DC, the SSR's are high voltage AC output type, you may be able to use a low level logic output type such as 24vdc in and low level DC output, but in this case it seems hardly worth using SSR when a small simple mechanical relay would do it.
Old 11-10-2010, 12:40 AM
Thanks Al
very clear explanation.
Tags
solid state relay problem
Using a solid state relay as a main stop relay garagefela General Electronics Discussion 4 02-26-2010 04:27 PM
Expert on solid state relay needed..... planekrazie General Electronics Discussion 7 04-13-2009 10:04 AM
Router 0/1 with solid state relay bigz1 General Electronics Discussion 6 04-24-2008 08:37 PM
solid state relay question aegfurn General Electronics Discussion 9 02-23-2007 09:09 PM
Solid state relay N4NV General Electronics Discussion 13 05-07-2006 12:19 AM
