Old 11-02-2010, 05:33 PM
Cartierusm is on a distinguished road
Can High Frequency from a Tig Hurt a computer that is Off?
Title explains it. Can the high frequency starting from a Tig welder hurt a computer that is off?
I've gone through quite a few computers in my shop that control my CNC equipment and I'm trying to figure out why. It stays very clean and the only thing that I think could affect it is the HF of my Tig, but the computer is never on when I'm using the Tig.
Help would be appreciated.
Old 11-02-2010, 09:05 PM
doorknob's Avatar
doorknob is on a distinguished road
I don't have any experience running a TIG welder in proximity to a computer.
Having said that, however, can you provide more detailed information about exactly what part or function is failing in the computers that have had failures? What symptom or failure mode do you see?
Old 11-02-2010, 09:08 PM
Not sure, twice it seemed that it was a powersupply, that could just be coincidence. Now the computer locks up when the CNC is on, such as TOTAL lock up,can't move mouse -- nothing. I left the computer on for a couple of hours with Mach 3 on but not the CNC equipment and it didn't lock up. So who knows.
Old 11-02-2010, 11:07 PM
Originally Posted by Cartierusm View Post
..... but the computer is never on when I'm using the Tig.......
This is not 100% correct. Most computers, desktop that is, are "on" in some sense because they are drawing power and waiting for you to hit the soft start button on the front. This button does not turn the power on it just tells the processor to come alive. Have you tried unplugging the computers when you are using the Tig?
Old 11-02-2010, 11:32 PM
What does it matter if it's unplugged? I don't mean that the computer always goes out when ever I use the Tig, that would be obvious. I use Tig and computer for years before anything goes wrong, but now it's happened again and I'm just trying to rule things out.
Old 11-02-2010, 11:49 PM
eaglezsoar's Avatar
Gold Member
eaglezsoar is on a distinguished road
Computer affected by Tig
Your original question:
As Geof tried to tell you, the computer is not necessarily off just because
the power button is pushed. It may appear to be off but current is flowing
through the motherboard so that it can be brought to life by a network card, a keyboard stroke or any of several other means.
So your question should be can high frequency from a Tig hurt a computer that is plugged in. The answer to that is yes.
Regards, Carl
Old 11-03-2010, 12:36 AM
LOL, OK, I revise my question. Although I always disable turn on by network card in the BIOS and I always disable Sleep or Hibernate.
Anyway, what would be a solution, should I just unplug the computer any time I'm using a device with High Frequency?
Old 11-03-2010, 06:16 AM
eaglezsoar's Avatar
Gold Member
That is correct.
Regards, Carl
Old 11-03-2010, 03:16 PM
thanks, makes a power strip come in handy.
Old 11-04-2010, 03:57 AM
Gold Member
RomanLini is on a distinguished road
Make it a power strip with an inbuilt filter. They don't that much more.
High frequency chopping/pwm locks up servo. Why? cncorbust.com Servo Motors and Drives 4 03-05-2010 07:37 AM
wiring high frequency spindle endgrainguy General Electronics Discussion 3 12-31-2008 12:01 PM
Thermo Dynamics/High Frequency/THC Firebass CNC Plasma and Waterjet Machines 12 08-18-2008 09:40 PM
High Frequency shaft rctoni General Electronics Discussion 1 10-20-2007 12:05 AM
Stepper-High Pitch/Frequency Noise azt34 Stepper Motors and Drives 0 05-18-2006 07:41 PM
