Old 06-28-2005, 11:21 PM
Nono's Avatar
Nono is on a distinguished road
Simple Limit switch Idea
O.K. This Might work. I have access to tons (literally) of satellite receivers. In the front panel there are very small buttons.
In a limit switch the circuit is always connected until the machine over travels. So I will just set up a rocker (spring loaded teeter totter) that holds the switch down until the machine hits it and the circuit would be broken and the machine would stop. Has anybody tried this? It could be put into a small box and mounted pretty easy.
If you have and don't use it, you still have it.
Old 06-29-2005, 04:38 AM
Gold Member
CJL5585 is on a distinguished road
There are CNC hobby machines on the internet for sale that use NORMALLY CLOSED PUSHBUTTON SWITCHES as limit switches. When the gantry hits the pushbutton the switch opens.
So, why not use normally closed pushbutton switches as limits? They are not heavy duty, but the cost is also not heavy duty.
Just my 2 cents.
Jerry
idea for limit switch, need opinions replicapro General Electronics Discussion 2 06-29-2007 06:59 AM
Limit Switch Question CNCRob DIY-CNC Router Table Machines 12 11-13-2005 09:01 PM
Limit switch adryan General Electronics Discussion 1 05-06-2005 06:02 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
