I have that board and I use the XYZ limits (configure as NC) and the Estop I would like to add Zero plate but I don't know where there is another Input header for the zero plate ... I was reading the board documentations and they said that pin 15 is an input too however how would I connect to it to give mach3 macro an input... there is 4pin header designated as: 16,gnd,gnd,17 --but those are output pins according to mach3 however I did read that one can configure those pin as an input according to the parallel port DB25 standards. Crap... all I wanted is just a zero plat...any ideas will be welcome Last edited by neric; 10-28-2010 at 02:00 PM. Reason: adding info |
| Neric, Is it possible for you to post a link for the manual for your driver board? With a bit more information I may be able to help. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| I am having the same issue. How was this accomplished? http://www.cnczone.com/forums/genera...ate_input.html |
| It was solved by soldering the probe wire to the open pad that is connected directly to pin 15 of the DB-25 on the driver board. Jeff...
| Mach Probe plug in what is "maximum z height for stuck probe" option do? | Rich05 | Digitizing and Laser Digitizing | 7 | 04-11-2009 12:05 PM |
| Any tips for designing a fixture plate / tooling plate? | thackman | Benchtop Machines | 9 | 12-19-2008 11:26 AM |
| Newbie- 3axis cnc kit? | jmacken | Want To Buy...Need help! | 1 | 11-03-2008 06:09 PM |
| Super Probe 17 Functions in one probe | thegimpster | PIC Programing / Design | 0 | 01-25-2008 12:46 PM |
| Aluminum: flat, bar, sheet, plate, tooling plate?????????? | Dan S | DIY-CNC Router Table Machines | 12 | 06-28-2007 12:48 AM |
