Old 10-25-2010, 11:49 AM
machinehead1970 is on a distinguished road
tripping the overload
i fit a 5 inch chuck on my 7x12 and now she trips when started in high gear.
can someone link me to a schematic so i can bypass the overload circuit.
Old 10-26-2010, 07:00 AM
vger's Avatar
vger is on a distinguished road
You don't want to bypass the overload circuit. That circuit is protection for the board. Bypassing it will most likely result in blown components on the controller. Here is a link to a place that does repair on these boards...
Gerling Laboratories has establi
As you can see, there are several versions of the controller boards and I don't know which one you have.
It may be possible to make adjustment to current limit to allow you to run with the 5 inch chuck without damaging the board. You might contact Gerling with your board info and get some help there.
Steve
Old 10-26-2010, 04:23 PM
Thanks for the reply Steve,
i found some info last night with the help of this forums bench top machine members and was able to adjust the pots to where she runs the chuck in high gear with 5.5 start up amps and 1.5 amps run.
i did not check how many amps it takes to stall the motor but it is more then before i messed with the pots.
She seems to be fine.
Need Help!- Circuit keeps tripping! greasetattoo Benchtop Machines 5 06-01-2009 09:10 AM
Need Help!- fuse tripping on 201 @ ~30 IPM cyclotron Gecko Drives 2 05-14-2008 02:54 PM
Tig welder tripping GFI's Dugg Welding, Brazing, Soldering, Sealing 15 01-06-2007 04:44 PM
Boss keeps tripping out on start up creep_pea Bridgeport and Hardinge Mills 4 09-30-2005 03:12 PM
Mach2 tripping e-stop chas Mach Software (ArtSoft software) 1 03-06-2005 05:42 PM
