Hello: I have a handwheel on my mill, pulse wheel I guess. It makes noise at times, like a frying/squeeling sound. If you move the wheel a bit it changes or goes away. Is this normal? Its a AB unit if that helps. |
| Where is the noise coming from? The hand wheel? Drive motors? Power board? You may have a very small following error causing a low drive level to the motor. With PWM drive, you may be hearing the pulses (high frequency) trying to correct the error. Moving the wheel, may be correcting the error causing the drive to stop trying to move to correct it. Steve |
| Normally there is very low current through a H.W. so there should be no electrical noise from the unit itself? As Steve mentioned, it sounds more like the servo making the noise? Al.
| Need to know if this is normal (DX-32) | EFI-Unlimited | Bridgeport and Hardinge Mills | 4 | 10-06-2010 03:11 PM |
| is this normal? | 15mgtar | Stepper Motors and Drives | 2 | 03-31-2010 06:01 PM |
| Need Help!- Gremlin or Normal? | Mr.Chips | Gecko Drives | 9 | 01-19-2010 07:12 PM |
| Problem- Lots of crunching noise from Z axis ballnut. Normal? | alexccmeister | Benchtop Machines | 21 | 08-26-2008 08:05 PM |
| Problem- This is NOT a normal noise | Dancy | Fanuc | 11 | 05-24-2008 04:26 PM |
