i got a woodworker's catalog in the mail today, as i usually do, and when i was thumbing through it, i found a little box that allows you to turn your router into a variable speed one. it claims it doesnt lose power at lower speeds, so presumably its a PWM converter or whatever. it appears to work at 120V, 15A and with a motor less than 3.5HP. so, it should work power-wise with a smaller bench-type single-phase milling machine. could you just plug the machine in and get a variable spindle speed? this would stop changing belts. also, if you attached one of those optical tachometers to it, you could get a decent speed control on the cheap. |
| Could you be a little more specific regarding the speed control. Pictures or a link to one would be helpful. If it is one of the small speed controls that I'm thinking of then it is a triac style. PWM speed controls are genarally larger in size and cost more. Router motors use a brushed type of motor and respond well to triac speed controls. Single phase milling machines use an induction type of motor and do not respond well to triac speed controls.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
| Probably one of these... http://www.mlcswoodworking.com/shops.../speedcon.html
__________________ Stupid questions make me smarter... See how smart I've become at www.9w2bsr.com ;-P |
| The controllers shown are OK on Universal motors, the type used in most power tools etc, they are for AC or DC brushed series connected motors, but do not use them on ordinary 1ph induction motors. Al.
| an ac motor designed to run on 60hz is not amenable to speed control of any kind - you can merely adjust power output dc motors are easy but if you want any sort of tight regulation under load you need a tach/controller integrated. this is actually pretty easy for relatively small motors up to 10 or 20 A if you don't mind soldering up some logic and pwerfets and a big old heat sink |
| CNC Controlled Spindle motor speed control | gregmary | General Electronics Discussion | 13 | 02-27-2009 07:01 PM |
| Taig Mill - need speed control for spindle | t2436jf | Taig Mills & Lathes | 3 | 01-24-2006 03:37 PM |
| BP spindle speed control | zcases | Mach Software (ArtSoft software) | 1 | 06-15-2005 09:06 AM |
| Spindle Speed & Feed Rates - Question | Moondog | DIY-CNC Router Table Machines | 1 | 07-23-2004 06:24 PM |
| CNC spindle and fluid control | replicapro | General Electronics Discussion | 0 | 06-22-2004 01:37 PM |
