Old 10-07-2010, 10:26 AM
mvas82 is on a distinguished road
Hobbymill 70kVA
Hi
Just got an opportunity to buy an industrial grade CNC Machining Center very cheap.
I have the space, but totally lost when it comes to electrical work.
Just wondering if it's possible, and if so the estimated cost?
I have three phase 230v in the garage, and the machine was specified with 70kVA. The spindlepower about 25kW AC + 3 axes. x,y,z.
MV
Old 10-08-2010, 06:35 AM
vger's Avatar
vger is on a distinguished road
70 KVA at 230 Volts three phase comes out to about 175 Amps. It may be possible the machine will require 480 Volts 3 phase which would not be uncommon. In the 480 Volt three phase configuration, it comes out to about 85 Amps. I would think breakers at 100 Amp for 480 Volts, or 200 Amp for 230 Volts would be about right.
Steve
