Old 06-21-2005, 11:55 AM
ahmed drdeer is on a distinguished road
a great refrance
dear maneger
my best wishes to this grate site for the grat sucses.
I am one of the very interested pepole whith this marvelos site.
I have a small idea and I dont knew if it is posibel or not.
I have a milling machine as many others have but there are meny difrances
in power or work aria you knew that. so whith out nolege in electronics I coudn't choose any devices to convert it to cnc machine for example
the stepper motors how can I calculate the force and insure that the power will be good to finsh my work pice strongly and whithout any harme to the motors, or the controll unit driver, which is a sensetive circuts it might be blowup. any way every one want's to have a hevy duty machine acording to the size of his machine.so a refrance to how to convert acording to the size will be amazing also whith a small comparing between the several products will be grate.
of course you have get the large idea and how to arrange it under a new corner titel in the site and I hope that will be usefull for all.
best regards.
ahmed drdeer
Old 06-21-2005, 12:04 PM
JavaDog's Avatar
JavaDog is on a distinguished road
Do you have any information on your machine? Size? Make? Model?
I know that information will help others to give you a better answer.
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Old 06-21-2005, 11:19 PM
Hi javadog
yes I have the full informations.
Drilling capacity .........................................1-1/4" 32mm
End mill capacity ...........................................3/4" 20mm
Swing.....................................................15-7/8" 405mm
Spindle nose to table (maximum)...................18" 480mm
Spindle taper............................................................ R-8
Diameter of Spindle sleeve................................ 3" 75mm
Head Swivel................................................ 360 degrees
Diameter of column.................................. 4-1/2" 115mm
Overall height (w/o stand)..................... 43-1/2" 1100mm
Machine Stand Height............................30" 760mm
Overall length........................................42-1/2" 1080mm
Overall width ........................................39-3/4" 1010mm
Motor power.......................................................... 2 HP
Spindle speed........................... 12 speed (120-3000rpm)
Forward/back table travel................................ 7" 175mm
Left/right table travel ......................................19" 485mm
Spindle up/down travel.................................... 5” 127mm
Working area of table............................... 28-3/4 x 8-1/4"
Net/gross weight....................................... 700 lbs.
that will be beter to get a good answer. but I like that my sugestion to the site is to provied any other member whith a big sight for there machines under several Size,Make,Models ? can you imagine that you will enter to the cnczone and just click on titel which called (how to convert your machine )or what ever then you will find the golden informations by your self instead of asking and wait for answers which is probebly the experince of one person only.(if you see the target clearly you will aim well).
thanx for your interest.
best regards.
Great Stuff expanding insulation for lost foam molds? WayneHill Moldmaking 8 06-01-2006 05:19 AM
WOW! This is great! I'm not the only one! eford8 DIY-CNC Router Table Machines 14 07-01-2005 04:20 PM
Geckodrive = great customer support! kra Gecko Drives 19 03-08-2005 08:35 PM
Great Aussie BBQ at my place ynneb Australia, New Zealand Club house 26 12-18-2004 12:31 AM
Great Freeware - "Convert" Swede General CAM Discussion 2 01-04-2004 04:35 PM
