Old 09-25-2010, 06:24 PM
Fastest1 is on a distinguished road
Optical switch circuit?
OK I ordered some optical switches from Mouser. I originally had used an "OPB380T51" during some testing because they were locally available.
http://www.alltheic.com/electronics-...datasheet.html
They worked fine but I wanted a different mounting configuration. I ordered some 'OPB832W55Z".
http://chipcatalog.com/TT_Electronic...OPB832W55Z.htm
They dont seem to work the same and I dont understand the difference. I havent been able to stumble upon any configuration that worked in any form.
Can someone explain the difference in how they are connected. Are the voltage requirements for operation different? I do like their mounting configuration. I really only want to use them for limits switches. I was hoping to run them via a 5v wall wart or similar, maybe from the PP? since it is optical? Thanks as always for any help or light you can shed!
Old 09-25-2010, 06:44 PM
Al_The_Man's Avatar
They are very similar and have similar electrical configuration for the most part, not to make them very critical, how do you have them connected?
Old 09-25-2010, 07:56 PM
Al, I thought I mimicked the configuration I had prior. I was using a variable voltage wall wart and was using anywhere between 3.5-5v during testing and it all worked fine. I was connecting the "red" anode to v+ and the "black" cathode to v-. I used the "white" collector and "green" emitter as a switch (that didnt work). I tried tying the green into the v- and vice versa. I tried it with an LED and a resistor. No luck. I used this diagram as my guideline.
http://www.fignoggle.com/workshop/ar...-wiring-how-to
Maybe I will try a different switch?
Old 09-25-2010, 09:05 PM
Al_The_Man's Avatar
The link points out the error of using the diode without a resistor in series, you have to ensure that the current rating of the diode is not exceeded, according to what the applied voltage is.
If you are testing it with just an applied voltage and the resistor shown it should work, it is not that critical, if driving it from a parallel port it may pay to use a 2n7000 buffer between port and opto diode.
Old 09-25-2010, 09:35 PM
I am still doing something wrong. I cant get it to work with the old switch now. I will be back.
Old 09-27-2010, 12:21 PM
GEBrown is on a distinguished road
I don't mean to hijack your thread, but I also have an interest in using optical switches for my home and limit switches.
Al, or anyone knowledgeable, since you seem familiar with these devices, can you help me understand - in very simple terms - the difference between these two?
http://www.optekinc.com/datasheets/OPB857.PDF
and
http://download.siliconexpert.com/pd...30-940-l-w.pdf
The 857 seems much simpler, but I'm still confused by the 30V and 5V circuits, in this case with a common ground. Does one circuit operate the LED and the other get switched on and off when it gets blocked? I simply want to use one of the limit switch ports (on my HobbyCNC board and Mach3).
Thanks!
Gary
Old 09-27-2010, 02:48 PM
Al_The_Man's Avatar
The first both the Transistor emitter and diode cathode are common so you can still use two separate supplies if you wish, just the commons will be at the same potential, i.e. not isolation, basically you would use this to transition from one voltage power level to another, e.g. 5v on the diode side and 24vdc on the transistor side, also you are committed to a source output to drive the diode side as the diodes sinks to common.
The second one not only allows isolation but the output is buffered with a sink to common output, and Schmitt trigger for fast switching.
Need Help!- Optical Switch boozeboy General Electronics Discussion 5 05-07-2010 06:40 AM
Optical switch, on when I expected off will gilmore General Electronics Discussion 9 04-23-2010 01:49 PM
Optical Switch w/Interrupt mechanism cnczane DIY-CNC Router Table Machines 1 11-10-2004 08:51 AM
WHATS THIS?? - Optical Switch?? High Seas General Electronics Discussion 5 07-13-2004 07:54 PM
optical switch natchez Xylotex 3 05-01-2004 07:45 AM
