Old 09-15-2010, 01:20 PM
parametric.ms is on a distinguished road
Need Breakout Board Schematic
Hi guys,
I'm on the way to build new mini lathe machine for simulation using mach3.
I'd like to make breakout board DIY. But I can't find the schematic/layout design.
Does anyone can help me to build the breakout board?
Old 09-15-2010, 01:40 PM
Al_The_Man's Avatar
What do you mean exactly 'for simulation' if this for testing and not actual hooking up to a machine, then you do not really need isolation and the I/O power could come from the PC 5v & 12v.
For simulating outputs a 2n7000 switch a 12vdc relay or LED would work, the 5v inputs would switch directly.
If you need an actual isolated output board then you could buffer some opto's from the P.P. output with 2n7000's or more compact, ULN2003 Darlington array.
Old 09-15-2010, 02:00 PM
sorry for misexplanation..
before I hook up to the machine, I'd like to test it first with all driver connected
of course I need actual isolated to protect my PC's.
Any idea Al? I've read on PMinMO look interesting
Old 09-15-2010, 02:15 PM
Al_The_Man's Avatar
Also a you using Vero or other perf board, or actually etching a PCB?
If using Perf board then you could hardwire in the 25pin cable, if you download the sheets for the ULN2003 and 4n35 opto, it is a simple matter to connect them.
The input side of your opto could be taken off the 12v PC supply.
Often the opto output can go direct to your drives etc.
There is no need to make it too complicated.
Old 09-15-2010, 02:27 PM
Now I'm using perf board for a while.If I found a great source for schematic maybe I planning to etching a PCB later.
Okay Al, I try to connect this "messy" wire first
Old 09-15-2010, 03:11 PM
Iron-Man's Avatar
Iron-Man is on a distinguished road
BoB schematic
Try the link below, complete schematics. I am currently using it with Mach 2 & 3 and EMC2 for testing of a servo system. I plan on refining it, moving all components to top side, plus adding relays. The Bob is in the upper left.
http://members.shaw.ca/swstuff/bob.html
Hope this helps,
Iron-Man
Name:	dsPIC Servo Amp2.JPG‎
Old 09-16-2010, 12:48 AM
Hope this helps,
Iron-Man
great reply Iron-Man...
this is what I lookin for.... May I discuss with you privately later?
Old 09-16-2010, 01:58 PM
Drools's Avatar
Drools is on a distinguished road
Thanks for this project, I will be routing a board ASAP!
Old 09-17-2010, 07:09 PM
Iron-Man's Avatar
Yes
Iron-Man
Old 09-21-2010, 06:15 PM
Drools's Avatar
I'm almost finished building the BOB Iron-man posted from parts in the bin. However I cannot find a 2N2222 tansistor. What would be a good compatible replacement?
  #11   Ban this user!
Old 09-21-2010, 06:36 PM
TarHeelTom is on a distinguished road
2N2222 is probably the most common utility transistor ever built. Any electronics house can help you find similar transistors.
Tom
  #12   Ban this user!
Old 09-21-2010, 06:37 PM
Mongkol is on a distinguished road
Question
Iron-man,
I am little puzzled.
Does it have charge pump system on this schematic or not?
Mongkol
Sieg C2 motor control board schematic? HankMcSpank Mini Lathe 2 09-09-2009 03:13 AM
Boss 4 RCK board Schematic jodybo Bridgeport and Hardinge Mills 1 03-26-2008 05:42 PM
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 07:55 PM
Breakout board joecnc2006 General Electronics Discussion 3 06-29-2006 09:33 AM
breakout board schematic giorgiocnc General Electronics Discussion 7 11-13-2005 10:02 AM
