Old 06-14-2005, 02:36 PM
PEU's Avatar
PEU PEU is offline
PEU is on a distinguished road
Power supply for 3 xylotex motors
I want to know if this power supply is enough to run 3 xylotex (269oz/in 2.8A) steppers:
Some friends told me that its not beefy enough, but I read somewhere in the forum that steppers like the xylotex ones don't draw the full ampere rating all the time.
I need some kind of confirmation, before actually begin to build the supply.
Thanks!!!
Pablo
Old 06-14-2005, 03:43 PM
fyffe555 is on a distinguished road
Peu,
Nice schematic. You might want to post this on the Xylotex forum but here's a few comments;
The Xylotex driver has a max of 2.5amps so you can size your Power supply to that. Note that at 2.5a you won't get the motors full 269oz/in which are rated at 2.8a.
If you expect to be running all three motors at the same time at full load then, theoretically, you need 2.5a x 3 or 7.5a. In practice this doesn't usually happen and so around 5a would be ok. As a guide note that the power supply sold by Xylotex is a 24vdc 4.5a supply.
The LM338 Regulator and its extra components are an unneccessary complication and may be a problem. Supplies for stepper drivers don't need to be regulated. If you have yet to buy the parts simply get a transformer of the correct secondary rating and drop the LM338. If you want 24vdc then that's about 17vac, if you want 30vdc then that's about 21vac. The Xylotex would work well anywhere within that range.
If you have the components then note that as drawn the transformer secondary is 30vac, the VDC after the rectifier with a 30vac input will be around 42vdc which is just over your capacitors ratings and over the max input range for the LM338.
Andrew
Old 06-14-2005, 04:06 PM
Al_The_Man's Avatar
The LM338 has a rating of 5A with good heat sink, if you already have a toroid transformer you could reduce the winding as has been outlined in these forums on a few occasions, and get rid of the LM338, if you want to stick to the Lm338, and want to increase the capacity, you could increase the current rating with a power pass transistor, the circuit of which you can get from the data sheets.
Old 06-14-2005, 04:58 PM
pminmo's Avatar
pminmo is on a distinguished road
http://www.mpja.com/productview.asp?product=7846+TR Makes a pretty good simple powrsupply and you don't need the regulator. You may need a couple of heavy current diodes to drop the voltage if it winds up on the high side of 32VDC. With a 30V transformer, you going to be right at the 40V max input for the LM338, and if you pull 4A, you would be around 64W for the LM338 to dissipate. i.e. BIG heatsink and fan!
Phil
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 06-14-2005, 05:44 PM
PEU's Avatar
PEU PEU is offline
Thanks Al/Phil.
Phil: I live in Buenos Aires/Argentina, when I ship something the post usually kills the deal, and this is the case, different was when I purchased THK rails at ebay
I received a reply from Steve from pmdx.com regarding my ps question (im using their drivers/Bbox), he said ripple is not the main concern and he recommended a simple power supply say: 20vac transformer + rectifier bridge (=28vdc) + 22700 uF filter for around 10% ripple, that should do the trick according to him.
Now I need a proper transformer
Pablo
Old 06-14-2005, 06:07 PM
pminmo's Avatar
I agree, a 20VAC transformer may not be easy to find. A 24 should be.
Phil
Old 06-14-2005, 08:05 PM
PEU's Avatar
PEU PEU is offline
Thats true, but custom built ones aren't that expensive here.
24vac x 1.4 = 33.6vdc which is dangerously close to the absolute maximum of the boards (35vdc xylotex or pmdx).
I have a huge transformer from a nonworking UPS that can be rewired, may be I save some bucks that way. Will ask for a quote tomorrow
Pablo
Old 06-14-2005, 09:39 PM
pminmo's Avatar
True 24 x 1.414 = 33.94, but you also lose 1.4v because of the 2 diode drop in the rectifier which give you roughly 32.5V a little breathing room. You can add two high current diodes in series and get another 1.4V drop to put you at 31.1. But if you can get a custom transformer, go for it.
Phil
Old 06-17-2005, 01:53 PM
PEU's Avatar
PEU PEU is offline
Well, Im in the process of having the custom transformer made by a very old motor shop
Speaking with the owner, an old and very nice guy, he gave me one of these for free:
From the label you can see that its only 15V - 20V peak but is 0.14F !!! so I tough I can use 2 more in series and have a nice setup of around 45v 40000uF.
What do you whink?
Pablo
Old 06-17-2005, 02:41 PM
ViperTX is on a distinguished road
Well you can, but the voltage would still be 15 VDC......hmmmm I wonder how the voltage rating is determined....I suspect it related to the ESR......
Old 06-17-2005, 03:10 PM
Al_The_Man's Avatar
In series across 30vdc would be 15v across each cap.
  #12   Ban this user!
Old 06-17-2005, 03:26 PM
PEU's Avatar
PEU PEU is offline
If I put 3 in series it should be 45v and 46666uF. Is this correct?
is this a good idea or is better to build in parallel from say 10x 4700uFx50v ?
Pablo
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 03:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 09:05 PM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 10:36 PM
power supply test dlenox DIY-CNC Router Table Machines 5 04-27-2004 08:06 PM
