Old 06-12-2005, 03:47 PM
drakesis is on a distinguished road
Power Supply Help
Hi All,
I had bought a toroidal transformer, a capacitor & bridge rectifier (together it should make a power supply of 68V 12A.) & I've started to connect my toroid up to the rectifier, & i measure 100VDC out from the rectifier instead of 68V? I also measured the toroid & i'm getting excactly 110VAC thats going in aswell going out. Am i doing something wrong?
Thanks, Will
William Desrochers - Excalibur Creations & Recognition
Raster Bitmap to Vector Conversion Service
Old 06-12-2005, 05:38 PM
The Toroid gives off 110VAC on both the primrary & secondary, when i apply the main power line to them on either side?
Old 06-12-2005, 06:13 PM
Al_The_Man's Avatar
Measure the output of the toroid without the rectifier connected, i.e. measure the AC secondary, if you had a capacitor connected as well as the rectifier you should have had approximatly 76vac.
Post the actual ac voltage on the secondary and that should tell all.
Old 06-12-2005, 06:40 PM
its ok now, i got it all working now. i had a the red & black connected to the main & the other red & black connected to the rectifier. Instead of the black & black connected to the main & the red & red connected to the rectifier. I now have my right voltages 50VAC, 70.7VDC.
Thxs.
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 03:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 09:05 PM
Is this power supply rating adequate? jerryrigge General Electronics Discussion 3 11-25-2004 10:06 AM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 10:36 PM
