Your probabally right there, The usual way is to bring the start windings out so that they can be reversed with respect to the run windings. Or if you bring out the two total series ends, of the cap, switch and start winding, the these two ends can be reversed before paralleling with the run winding.Originally Posted by kong
Also the configuration of the switch contacts have to be known.
BTW if that motor is 30yrs old, I would check the bearings and the switch, it would save grief later.
LinkBack URL
About LinkBacks
