Old 08-28-2010, 11:39 AM
lovebugjunkie's Avatar
Gold Member
lovebugjunkie is on a distinguished road
ETD29 transformer core/bobbin needed
I found a kit I would like to build that requires a transformer bobbin/core. They list it as:
ETD29 transformer with 2 x 3C85 cores a 13-pin former and 2 retaining clips
I have not been able to locate this part in the US.
Can anyone point me to a retail seller for this part.
george
Old 08-28-2010, 01:16 PM
vger's Avatar
vger is on a distinguished road
George,
You must be looking at a fairly old design. I found a note from the year 2002...
"Most of the European tx designs utilize the (now defunct) 3C85 series of ferrite cores."
If it was defunct in 2002 I'm not sure you will be finding one except in salvage.
Steve
Old 08-28-2010, 07:21 PM
Gold Member
Steve,
Thanks for the reply and info. After reading your reply I checked ebay as I have found it a good source for old parts.
http://cgi.ebay.com/ETD29-ETD-Ferrit...item3a5a4875fa
The only info the article gave about the winding is:
Secondary winding of 45 turns of .25 mm enameled copper wire.
Primary winding is 4 turns of 14 x .20mm or 14 x .18 mm figure 8 cable
And since the author said it can output as much as 900 volts to the transducer I did not want to substitute a part that “may” work.
Article is in the Silicon Chip magazine.
http://www.siliconchip.com.au/menu_2...s/section.html
One on building A Large Ultrasonic Cleaner
George
Old 10-06-2010, 11:47 PM
@ndovas is on a distinguished road
Large ultrasonic cleaner (Question)
Hi lovebugjunkie,
Did you already finish to build this project?
I´m building it to, but i have a problem, it seems that i can´t get enough power or cavitation...
Yours is already working fine???
Thank you so
Transformer core. ozzie34231 General Electronics Discussion 10 09-19-2009 04:33 PM
Need Help!- any one know where i can get plans for oscillating bobbin sander m.southern WoodWorking 13 07-06-2009 07:33 PM
24VAC 10A transformer needed in New Zealand blasttiod Hobbycnc (Products) 5 08-28-2008 11:39 AM
TOROID TRANSFORMER info needed - have spec sheet tekno General Electronics Discussion 1 03-09-2006 07:44 PM
3 phase transformer needed pauluk General Electronics Discussion 1 12-26-2005 03:02 PM
