I am in the process of troubleshooting a problem with a Trumatic 240 punch machine that uses a Bosch PLC/input/output cards. I am used to working with Allen Bradley systems and am not familiar with Bosch. With Allen Bradley if I look at a print and I want to verify an input, it tells me the rack position of the card and the input on that card. Example if I am looking for I:07/03 I would go to rack position #7 and check the #3 input. But with Bosch, the print might say input 42.4. How do I determine which input that is? Please let me know if I need to clarify my problem more clearly. Thanks |
| I am not familiar with Bosch PLC but when working on unfamiliar PLC's I have found there is always a certain pattern, so often the I/O is in either blocks of 8 or 16, if it has descrete cards then establish if it has this pattern, then differentiate between Input and output, They usually start lowest from the processor and work up the farther away, the next step is to try and identify by wire number, the wiring is often labeled with the I/O bit number, in this case 42.4, this is most likely word 42 bit 4. if the input cards have LED's, try operating the input manually if possible, or another input you can identify by number, such as a proximity or limit switch and get someone to see which LED registers, then it might be possible due to the physical location of that LED to decifer the I/O module layout. You have to become an Electrical detective. Al.
| Do you have a model # of the PLC, I might know of a source for a manual in PDF if it is the right number. Al.
| It's a Bosch NT-400 PLC. I've actually been pulled to service other equipment in that facility so I haven't bee able to look at this machine since my thread posting but it is still an active issue. Thanks yet again Al, you da man! |
| Medelas Mo controls | justin | Mazak, Mitsubishi, Mazatrol | 17 | 01-17-2006 06:46 AM |
| Need Help Guys (Retro Fit with Fagor controls) | kevpau | Post Processor Files | 1 | 05-12-2005 06:54 AM |
| Bosch Rexroth linear rail left (Netherlands) | Tjippy | DIY-CNC Router Table Machines | 10 | 05-01-2005 08:06 AM |
| Controls options | djshop | General CNC (Mill and Lathe) Control Software (NC) | 1 | 01-06-2005 09:59 AM |
