Old 08-12-2010, 10:22 AM
Khalid's Avatar
Khalid is on a distinguished road
Control Circuit for VFD
Hi guys,
I have recently purchased 2.2KW PUMA VFD.. I have to install it on my CNC Converted Mill... I just want to know:
1- How to wire Reverse/ Forward button
2- I have seen some dials on machines that are used to increase / decrease the speed of the spindle motor.. Are these dials are special one or just Potentiometer.. I want to know what rating of these dials?
3- The circuit for controlling the VFD via Mach3.
Best Regards
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Old 08-12-2010, 11:51 AM
Al_The_Man's Avatar
It depends on whether you want manual control or M3/M4 through Mach as well as analogue control input, the manual pot would be 5-10K linear pot.
Old 08-12-2010, 12:44 PM
Khalid's Avatar
Thanks Al,
I want to control through Mach3... However, I am confused, How can be manual control of Reverse Forward direction of motor through the remote switches wired to the VFD!!!..
In the VFD the Reverse, Forward and Stop connections are given.. Should i use Normal Switches or something else..
For the Manual Linear Pot, Should i get from the radio mechanic workshop?.. Can i use Stereo/Volume control or something else?
Thanks for the reply.
Old 08-12-2010, 12:50 PM
Khalid's Avatar
Currently studying the following article
http://www.cncathome.com/vfd.html
I need some schematic/ Pictures of General VFD wiring.. I know what terminal i have to give input power supply and what i have to attach the motor..but i am stuck into Reverse/Forward switches.. What type of switches these are and how they are installed..
Old 08-12-2010, 02:21 PM
Al_The_Man's Avatar
For machine controlled fwd/rev you need two relays controlled from Mach.
Manually you can use two simple push button maintained buttons or if the VFD allows it, momentary style, depending whether the VFD has options for this control, the manual should describe the fwd/rev hook up.
If you use a pot for control you need a linear one, volume controls are logarithmic taper.
For speed control from Mach you need a PWM to analogue converter.
Old 08-12-2010, 02:40 PM
krak's Avatar
krak is on a distinguished road
It appears that the drive supports modbus communications. You might want to consider that as an option.
Old 08-20-2010, 09:57 AM
Khalid's Avatar
Hi Al,
What relay should i use? Can you help me completing the attached sketch for the relay?..
IN ATTACHED SKETCH hOW THE RELAY WILL BE INSTALLED??
Krak:
Yes the VFD support modbus communication but the hardware for it is little expensive for me!!
Old 08-20-2010, 11:12 AM
Al_The_Man's Avatar
If the VFD has sourcing inputs, which it appears it has, as the inputs are switched to common.
Then in that case you should be able to connect the collector outputs, 4 & 4 each to SR & SF direct.
A relay was mentioned in order to get isolation, but you will get that through the opto's.
Old 08-21-2010, 04:18 AM
Khalid's Avatar
Thanks Al.. I hope the Common wiring that i drew on the sketch is right...
New Machine Build- electric circuit for cnc 3 ax control shlxtn Stepper Motors and Drives 8 11-16-2009 03:12 PM
Need Help!- 240 VAC Control circuit GaryJ General Electronics Discussion 2 11-13-2008 03:33 PM
Need Help!- DIY stepper motor control 4A circuit?? veenie Stepper Motors and Drives 1 03-19-2008 08:04 AM
Need Help!- Control Circuit Board Pin ID j-miller.6 Fadal 0 01-27-2008 03:00 PM
Spindle Control Circuit? boguski.1 DIY-CNC Router Table Machines 10 03-17-2007 10:24 PM
