I have been doing a lot of work researching and designing a new PWM motor controller board for use with universal type motors. in my case specifically the Dremel tools, but any universal motor can work. I currently have a PWM system built and a dremel tool modified with the internal speed controller removed and the PWM system wired to the dremel tool and it works fantastically! I am now working on an optically isolated version to make it safer. I am also working on a speed feedback system as well. I have been considering offering some version for sale if there is enough interest. Versions that might be of interest would be: 1-basic - manual control with opto isolation of control circuits from the AC line. for dremel and trim routers etc. maybe a max of say 5 amps??? 2- Med - manual control with speed feedback. same as above with feedback system 3- full bang - microcontroller control of speed. PWM and Step/Dir signal inputs, speed feedback, controlled start up and shut down. etc. I could sell them as board/kits or full finished products if there was more interest one way or another. also possibly full kits with modified dremels etc. Zc |
| well. I don't have all the details worked out yet. But the PWM controller would run off of 120Vac and provide 170vdc to the PWm circuit and would be electronically limited to 70% to = the 120V line so as to not run overspeed. but will have some headroom for high loading. I could probably do 5-10 amps easy enough. if there was particular demand for higher current or lower voltage etc that is easily do able. the basic controller would be priced about $99 for a finished controller and maybe $50 for a kit The advanced controller would probably be $299 and I am totally guessing and tossing these numbers out there. A lot would depend on what the total cost would end up being. cost plus $20 or something. Zc |
| A few years ago I picked up a surplus Universal motor and controller, the controller was built around the TDA1085 IC, originally meant to control washing machine motors. The motor had a very simple (crude) pulse wheel feedback, I was very impressed with the performance, especially low speed for band saw use. It also has current limit built in etc. It can be used with a Triac to control the motor with AC or fire into a bridge and use the motor in the DC fashion. Mine was designed in latter style, In DC mode. Once designed, it could be much cheaper to produce, maybe. Al.
| Stepper motor boards. | 30tooo | Want To Buy...Need help! | 4 | 04-16-2008 11:08 AM |
| Micron Spindle Motor /controller /wiring | jalessi | General Electronics Discussion | 0 | 01-12-2008 06:35 AM |
| Pulse generator / controller boards for EMC.. which one? | ewest | LinuxCNC (formerly EMC2) | 3 | 04-23-2007 05:53 PM |
| Spindle motor and controller suggestions | ZipSnipe | General Metal Working Machines | 2 | 05-12-2006 08:21 PM |
| How do the controller boards etc work? | Hack | General Electronics Discussion | 3 | 12-13-2004 02:37 PM |
